[Odin] Froyo leaked packaged custom ROMs w/root and clockwork **UPDATED**3/25
can anyone offer me any advice? Im on SC 2.9.2 and I havent gone to anything EC01 because I have been under the impression that new better things are coming soon. I would be comfortable moving to the EC01 rom, but I would have to use a friends PC to do so, so I would rather not go through the hassle if something else will be coming soon.
I dont know if anyone has any insight or advice, but any would be appreciated. Thanks!
I would hold out! I have been holding out...:)
Which file are you trying to update? Are you trying to change the script like the instructions say in that thread? If so, at the top of the page when you are in root explorer should be a white or gray rectangle that will either say R/O (Read only) or R/W (Read/Write.) Whatever the box shows is what you will switch to if you click on it. So in order to be able to write the box needs to say R/O.
the box does say R/O :'(
I was not trying to run the script but just edit it manually
per:
Instructions:
With Root Explorer (or similar app)
go to /etc/gps.conf
In Root Explorer long press on the file and select open in text editor
Change the first line from:
NTP_SERVER=north-america.pool.ntp.org to NTP_SERVER=us.pool.ntp.org
i will pull the script and give that a try
report if i stil have issues, well if my phone has issues that is
Thanks [Odin] rooted
Thanks to everyone involed with Android Central and to the rooting process. I came from Blackberry to a Samsung Facsnate I500 on Verizon. I hated all the junk they put on it , I did the root with superclean now I have a rocking phone. Thanks again to all that helped.
If this is not appropriate to ask this question in here, you can delete it. I been here a while but I didn't used the custom up date yet since I am unsure how to do it. If someone would be kind enough to help step by step. I would really appreciate it.
Heres your step by step instructions...Its simple thanks to droidX. Make sure if coming from 2.1 that you go 2.9 data wipe first than flash 2.9.2. http://forum.androidcentral.com/ver...tom-roms-w-root-clockwork-updated-3-25-a.html
Reactions: jjong
I'm also not sure if this the right place to post this question. Mu apologies if it is not. I recently installed SC 2.9.2 with DroidXCon's odin method (thanks, DXC, great job man). The only problem I'm having is with google maps. When I zoom in close enough to get
3d renderings of buildings, the phone freezes up and then force closes on me. Any suggestions?
Does SC 2.9.2 come with the latest version of CWM? Or do I need to download another?
The SC 2.9.2 in that thread sfobrien linked you to has the latest CWM. According to GizmoDroid's instructions in that thread, you actually have to flash both. So flash the CWM via ODIN, and flash the 2.9.2 file from that thread in the new CWM and you will be all set.
  • 2nd if you were on eclair and wanted to upgrade to froyo you should have heeded my warnings on the original post about not using the no wipe package if you were flashing from eclair.
Just to clarify, as I'm coming from Eclair, was I correct in assuming I should flash 2.9, followed by 2.9.2?
Because I did that and successfully kept all my apps and got into a lovely loop of force closing. Took the advice you posted about going full stock (thank you for posting that link, by the by, as I was basically lost as to where to find that), so hopefully everything will work out, but it was rather confusing to see all my apps still present and crashing.
the problem is that you flashed 2.9 but did not fully turn on the phone. it will only wipe when you turn the phone on . sounds like you flashed 2.9, then immediatley flashed 2.9.2 which would give you superclean 2.9.2 but it wouldnt wipe causing the force close loop. sorry i should have mentioned turning the phone on after you flashed 2.9
Reactions: Tari
Yeah, that would be it.
I guessed as much, and tried flashing back to 2.9 and turning the phone on, but it seems like it was too late by that point. :P
Thanks for the help. :)
Thank you for your help. I read the first page. I also read the beginner guide since I am coming for the first time, so I am bit confused. If you have or anyone has time to take me step by step I would appreciate it. Btw, out of curiosity I download OTA of 2.2 and it is really bloated with things I don't need. Can I still do the steps.
Thanks
Thanks
The Thread I gave you gives great step by step on how to do it. Just take the leap. Im at work so cant take you all the way, but there r great people here to help you.
I have SC2.9.2.. How can update it to ED01 ? Thanks
thread already dedicated to this for questions on that post there. http://forum.androidcentral.com/ver...70-howto-get-ed01-official-froyo-quickly.html
I understand there are now methods of getting to ED01 for those of us who are rooted, themed, etc..Just wondering if there is any chance we could see a very nice, always well put together, Droid X Con Odin Package (complete with Kernel, Radio, Root, etc) with the ED01 debloated/debinged release that Adry posted early this morning...thanks in advance..
Taken From Gunnermike's Thread..
Dan (aka droidxcon) wont do this himself, so i will. how many of you have working phones because Dan sat up all night and held your hand until you got your phone working. how many of you would have bricks if not for Dan. how many of you would never have rooted in the first place if not for Dan. beyond that, how many of us have been helped in one way or another by Dan.
All that to say Dan's phone is broke. as of right now he does not have a fascinate. as you all know they are not cheap. i know times are tough right now, i cant give alot, but i can give a little. if alot of us give a little, then maybe we all can give enough for him to get another fascinate.
so come on guys, lets help dan like he has helped us. i will start off with $5.
https://www.paypal.com/us/cgi-bin/webscr?cmd=_flow&SESSION=dvJmFq_-Xtn_-QwND0oN3wtPymZZXIFQ2PAIEV6jOOn8L_URZt2bHn9gPCO&dispatch=5885d80a13c0db1f8e263663d3faee8d5863a909c4bb5aeebb52c6e1151bdaa9
Flash EC10SC292x_DXC.tar
Sent from my SCH-I500 using Tapatalk
On 3/28 I flashed EB16 and was having some issues with it and you told me to flash EC10 with 2.9.2. I used the link in the first post of this thread, EC10SC292x_DXC.tar. I've been using it ever since but I never bothered to look at the "About Phone" screen to see what I have (dumb I know).
It says my Kernel version is 2.6.32.9, Baseband & Build number are EB01.
Do I need to flash again for 2.9.2? Was there a problem with the mega upload link that has since been corrected? I know that I used the link provided..
Thank you for your time. I was about to try to it myself now after reading some threads,; but with ED01 official release, there is no stay awake on development. Does it matter. As I earlier, if someone can spend some time to help step by step. That would be great. Sorry if I am asking for help since this is the first time attempt and are bit afraid.. I like the release. Only thing I dislike is the bloated and games on the phone. Thank you for your time.
You might want to hold off for now there is some great stuff going to be happening soon...but Im not sure about the stay awake thing, someone with more experience with that will im sure be able to help you.
birdsong2000
