[Odin] Froyo leaked packaged custom ROMs w/root and clockwork **UPDATED**3/25
Yea it's completing every time now, just fails at the end..
(<ID:0/006> Added!!
<ID:0/006> Odin v.3 engine (ID:6)..
<ID:0/006> File analysis..
<ID:0/006> Enter CS for MD5..
<ID:0/006> Check MD5.. Do not unplug the cable..
<ID:0/006> Please wait..
<ID:0/006> Checking MD5 finished Sucessfully..
<ID:0/006> Leave CS..
<ID:0/006> SetupConnection..
<ID:0/006> Initialzation..
<ID:0/006> Get PIT for mapping..
<ID:0/006> Firmware update start..
<ID:0/006> cache.rfs
<ID:0/006> dbdata.rfs
<ID:0/006> zImage
<ID:0/006> recovery.bin
<ID:0/006> factoryfs.rfs
<ID:0/006> modem.bin
<ID:0/006>
<ID:0/006> Complete(Write) operation failed.
<OSM> All threads completed. (succeed 0 / failed 1)
I just downloaded a stock file and installed it instead of the full one as you suggested and and went through the process and passed and i was able to boot up, so now I am up and running. Thank you very much for your assistance, glad there's people on here like yourself who know what their doing & don't mind helping others.
Thanks , Glad it worked out. Mark the original USB port you used so you know not to use it again for critical functions.
Purchased my new Samsung Fascinate Galaxy S a week ago, and I love it... Until I saw all the garbage Verizon installed on it. I had it in a tolerable condition using the Enhanced Google Search and LauncherPro, but I just received the Android 2.2 update from Verizon. Bing is back in my life, and I am not happy. I decided I had enough, and my friend and I rooted the phone last night. (I am total noob regarding this stuff.) However, we tried using ROM Manager to flash with "Super Clean ROM" and encountered the same issue everyone else has. We stopped there. I am not looking to take over the world or turn my phone into ("sex") (saw that comment from someone and it made me laugh!). I simply want a clean ROM that allows me to use Google instead of Bing and doesn't have all the garbage Verizon installed. I would like to follow the original post, but I am concerned of rendering my phone unusable. Is it as simple as following these instructions and downloading the "Debloated/Deodexed Froyo Leak+root+Froyo Clockworkmod" ROM? Thanks much.
First off ROM Manager with the fascinate is a big nono.
And if you want a simple package that comes with root and is debloated check out landsharks thread.
http://forum.androidcentral.com/verizon-fascinate-rooting-roms-hacks/79124-odin-official-froyo-ed01-packaged-custom-roms-w-root.html
Follow directions in his post. He also has CWM all link in there too.
Thank you pikanate! I read the post, and it looks promising! I do not believe ROM Manager caused any problem other than it failed to flash the ROM. (The CWM writing was blue after restarting the phone.) The phone has been running "fine" since my attempt, but it's obviously not in the state I desire. I will post any further questions under the thread to which you directed me as it appears to be relevant to my situation. Thanks again!
ok i have a galaxy s 4g the newer one from tmobile and i downloaded that mod battery app and idk what it did but my phone wont start and i tried these steps on here to see if it would work but its not any help please thanx
Because that's a Galaxy S 4g and this is the Fascinate forums, you need to ask them there to help you, it's a different phone. Go here Samsung Galaxy S 4G
Ya, that mod wouldn't work for you more than likely. If you want the equivalent then use root explorer to find the bstats.bin file, delete it and reboot your phone.
OFT BRICK
Resolution
First off DO NOT PANIC. there is a simple solution, just remove the battery , plug the phone into the computer, press and hold volume down and it will enter download mode. Please review all the steps oulined in this thread and try and flash again
this is where im at... and even i retry it comes to this again..
OFT BRICK
Resolution
PC or laptop,?
Sent from my SCH-I500 using Tapatalk
need some help.... just to make sure i did this right... i flash both 2.9 and 2.9.2 via odin right??? i did that and now on reboot i get force close loop!!!!
Never freak out unless your phone doesnt turn on , like there is no power or anything on the screen, then maybe worry
ok i flashed 2.9 via odin and when i turned it on it still came up with FC loop..
edit... ok i booted into recovery, but it rebooted and came on to the home screen with no problem... should i reboot again just to be sure before i do 2.9.2???
dumpsterrentals89
