[Odin] Froyo leaked packaged custom ROMs w/root and clockwork **UPDATED**3/25
Yeah wipe data and cache and im assume you are using 2.4 from adrynalynes thread in whiche case yes flash it from clockwork
Just wipe all data and re-flash the same super clean 2.4 that's already on my sd card?
Sent from my SCH-I500 using Tapatalk
hey, ive never done any rooting or flashing or anything like this to a phone. tonight was the 1st night i ever did anything like that to my fascinate. i used the super clean 2.4 version and im happy with froyo but i would like to somehow find out if i can get rid of this and just get the regular version from the video with all the bloatware & such. the superclean version varys from the one in the video and is not a pure black notification bar. also the dropdown menu from the notification bar is a light grey i dont like. also theres no samsung media, music, video hubs or any samsung widgets. it seems stripped down and not as nice looking. id rather the regular stock. plese let me know how i can do this. i tried to repeat the procedure that i used to get it originally and put the version i wanted in the pda seciton of odin and it did nothing. it said all threads completed success 0/ fail 0...some one pleeease help me ..... please
First Download and install Drivers HERE
Disable any antivirus running
Use USB ports in the back of the computer, if you already are change it to another port in the back of the computer
Make sure your battery is out of the phone during the entire process
this is the original leak fully stock
Full Stock Froyo Leak+root+Froyo Clockworkmod
EB01_DXC.tar
Reactions: pdubsfc
update.zip
once I have update.zip on my sd card do I need to redownload it everytime I want to make a change? or is it the same version all the time?
Well it worked today. I had to wipe data and now no issues. Good thing I used ti backup last night. Thanks to everyone for all your help
what is the update.zip file for????? i have sucessfully complete the rooting to EB01 im just curious about the update.zip file
Has anybody experienced decreased battery life since getting this ROM?
EB01 kernel is not that great on battery life...couple weeks there will be custom kernels.
Update.zip leads you into clockwork recovery when you aplly sdcard:update.zip from stock recovery
Okay thanks so much. :) I've never done something like this before. Is it easy as long as I follow the steps correct?
Yeah and we are usually pretty good as a community providing support
That's no reason to stay stock .do you like stock? Do t you touch wiz? Each method is as easy as tge others so your user level does not matter.. Try super clean 2.4
Thanks josh :)
Okay thanks again so much. Should I just stick with the full stock froyo since im new to this?
Touch wiz is the samsung interface like the dock at the bottom with the four icons. And the app drawer being horizontal or the samsung widgets....etc
I don't mind stock. Im not sure what touch wiz is.
Promeetheus
