How do you flash ROMs without a SD card??As someone who used HTC phones for a while, this isn't really a concern.
Long battery life ensures that I never had to fumble with the hassle of carrying and constantly swapping extra batteries (we're not sure yet what kind of battery the GS6 will have though). And the deterioration isn't much of a concern either. Modern batteries are rated at a super high number of charge cycles; they'll go forever without significantly degrading. I never kept phones for two years even. If you keep it for a really long time, it's probably not much of a hassle to get it replaced if you really want to. You'll probably have to send your phone in for a bit, or maybe just a trip to your local carrier store.
Yeah but what about when you factory reset or wipe system, data and internal SD for a fresh ROM install? On my s5 when I do that it deletes everything on my internal SD.You put it on the local storage.
How would you transfer it if you have no SD card lol? You can't transfer files from a computer to your phone in recovery mode.1. Reset and wipe system
2. Transfer ROM to internal storage
3. Install ROM.
Then it isn't a fresh/clean install....Just do an advanced wipe and leave the internal storage that houses data intact.
Yes it is. All the data for apps and stuff is wiped but your personal files stay in place. There are different partitions for a reason. There's absolutely no need to delete your pictures for a fresh install.Then it isn't a fresh/clean install....
