Optimus S, now with... FLASH!
I would start with ZVD update. Then root, custom recovery, custom rom then install this...
Thanks, I guess I have to root the phone. I was trying to avoid it but I guess I can't. I'm on ZVC, bc I know my tethering app will work.
I really want flash, it kinda sucks having to use skyfire all the time. I might update to zvd, then use gingerbreak.
I did the steps couldn't find flash in my applications. Then I downloaded a zip viewer found it abd was able to install. Now its in my application manager but nothing is viewable or playable on my browser. Do I need to root or something? Oh and I have the 2.3 gingerbread update
In opera mobile (not mini), I go to the regular YouTube website, it still says "You need to upgrade your Abobe player to watch this video" In fact it just doesn't work in Opera Mobile. (I removed the stock browser from CM7)
Try one of the newer builds out there, i know 10.2 and 10.3 are floating around. on the boards
Well THANKS HAHA!
Apparently Opera just simply doesn't support flash. Running the Dolphin browser and it will run flash. Have the Adobe Flash 11 installed, however, Dolphin is very slow and laggy depending on the flash object.
Either way, I get my Motorola Photon 4G in tomorrow, so I won't worry about this on my LG.
Marlene
