Thanks a ton!!! I'll try right now! You are the man! :thumbup:
Sent from my LG-LS670 using Android Central Forums
If it works, I'll package it all(including zakman's fix) in a flashable zip for everyone.
sent from my un-dead sammich.
This zip should include a key switch![]()
So wait we need to be ZVJ or ZVD to try this out? Cuz I'm ZV4.. >_<
i think he meant just cm10 in general![]()
If you don't know what ZV(x) you need to be on then you might need to wait for one of the OV devs to make it.
Sent from my shole using Tapatalk 2
while you're at it, in the zip you should include the free jelly beans![]()
The Optimus V is ZVD only. The ZV4, ZV5, and ZV9, are all branches of ZVD. ZVD is Froyo firmware, and since the V only comes in Froyo(stock), it uses ZVD, the numbers are just Virgin Mobiles versions of ZVD.
ZVJ is LG Optimus S firmware for stock gingerbread.
I'll probably end up packaging everything into JB gapps, for simplicity of flashing
NOT ANYMORE IT ISN'T THANKS TO SAMMYZ! Fully functional ZVJ firmware for the Optimus V.
Is that kosher? I know that the devs for all the OV ROMs have removed gapps from their ROMs, due to Google's legal requirements. I know that there are versions of gapps that are slimmed down, but is it legal to add things?
Yeahhh hahah it is a VERY complicated method.
