Please help... My Galaxy S4 won't let me enable Wi-Fi
Re: Please help... My Galaxy S4 wo'nt let me enable Wi-Fi
My Wi-Fi suddenly stopped working too. The toggle to enable Wi-fi would not work. Removing the battery did the trick! Thank you!
Update it to 4.4 Kitkat, as that's the only solution i see for this problem.
I've had this same problem, I know how u guys feel so thatswhy I made an account.
Some took battery out, some smashed it on the table, neither worked for me xD
Basically all you have to do is root... it's super easy with step by step tutorials everywhere on youtube.
This was the link i worked with: [RECOVERY][ROOT] Samsung Galaxy S4 Mini LTE (GT-I9195) - xda-developers
Good luck guys
PS: dont be to shady about rooting ur device, I know i was, but it's seriously easy and you can un-root it again. Not that im going to but , its possible and also easy...
Besides if it wasn't for the developers/hackers me and couple hundred others would still have been stuck with this wifi problem. Oh and F*** samsung and it's service. I got this lame wifi problem by updating my device through samsung kies, f**** bull****
My S4 was fine on 4.2 when I updated via kies to 4.3 same issue wifi switch would not switch on, nothing I did helped. So I flashed 4.2 back onto my S4. 4.3 seems just a little too buggy, even after a revamp. My GS4 19505 is stayin put for now. ....
I had the same problem my wifi won't turn on but when i removed my battery it workt i have no idea how it
works then but it works!
Stephen Griffiths got it for me, simple little config error, he's a life saver.
Internal SD Memory the Path /data/misc/wifi/ the File named wpa_supplicant.conf is having issue.
Not going to guess what what was done on your side only that wifi cannot read that file so it just shuts off.
you need root to view this file, I suggest renaming it, reboot then enable wifi again and it will create a new one.
you will lose all saved passwords from the beginning of time but will be able to use wifi again.
I don't even have that file! Mine comes up with softap.conf and the wpa_supplicant is a folder! Any suggestions?
This WORKED perfectly!!! Thank you so much. I just registered to this forum to post here and say thank you.
I Recently flashed a custom kernel to my Galaxy s4 and i was playing with it when the wifi stopped working. So i tried a lot of things, removing battery and other non-sence. But deleting the /data/misc/wifi/wpa_supplicant.conf file fixed my problem. I backed up the file before deleting it. Then re-booted and my wifi turned on imminently ! Thanks again.
JUST Turn off your S4 and take the battery off.
Then put the battery back and turn on.
It works.
Thanks a lot, it surely helped me out and i have also shared your solution on other forums too to the people that were facing similar issue.
I did the battery pull out suggestion and it worked. Just bought the phone yesterday, though, and I HATE having stuff that looks it could be a hardware issue rear its ugly head this early on :mad:
Deleting the /data/misc/wifi/ File named wpa_supplicant.conf worked for me.
Deleted then rebooted.
Please, can you tell me how to acces internal SD card!!!!
Gasho
