PRL Swap for the V on VM (latest PRL for Sprint Towers).
Okay. I am running IHO BACKside, and I rebooted into recovery, yet I am still getting the "failed...phone does not answer" I have my COM assigned to #1, tried all available between 1 and 10 (only 1,2,3 and 4 are open) to no avail.... ??
make sure your connected to the phone com port and not the phone modem com port, that was where i went wrong
It may be the recovery you are using. What recovery do you use?
Where is the difference? Where do i make sure I'm connecting to the right one? Is it in device manager or the CDMA step?
And I am just running ClockworkMod recovery, or whatever is automatic in IHO (hold down unlock button->press reboot->recovery)
Device Manager. What Kraven says is right! That's where i went wrong too. You cant use the Com Port from the modem. Make sure you get the LG drivers from the link in the thread. Others will NOT work.
Is the latest prl 60683?
EDIT: On a side note, when I flashed the PRL, data was working fine, but sms/mms/phone calls stopped working. Did I do something wrong?
I had to perform a hard reset by removing the battery and that resolved the issue. A reset did not fix it.
Sent from my cm_tenderloin using Tapatalk
For some reason, even though I have my network to home only... it still connects to a tower that i am not authorized to use. Data works, but sms/mms/phone does not. Any suggestions?
Is 61007 still the latest Virgin Mobile PRL?
Have the most recent Optimus V phones been coming with something newer than that?
61007 is around 6 months old (or more).
I believe 60685 is the latest.
Don't go by the numbers, they aren't in order apparently.
Reactions: Cr0ppy
Is there any point to updating to the latest one? Would it make any difference? I'm on 61677 as of right now.
The latest Sprint PRL that I've found is 60686 at:
xda-developers - View Single Post - [UPDATE: 3/6/12] PRL Testing Thread [WIP] - Testers Needed!
I'm still using 60685, as 60686 has only minor changes that do not affect my reception area according to:
BatonRougeBroadband.Info - Home
61007 is the Virgin Mobile PRL that came with my OV purchased a year ago. This is the first that I've heard of 61677 so it may be Virgin Mobile's latest PRL? If someone could pull and post it, digiblur@HowardForums could examine it to confirm.
Reactions: LeslieAnn
61677 is a hybrid PRL that was posted over at XDA. It is a merge of 60677 Sprint PRL and 61007. You can download it from that link as well if you choose to.
Reactions: tli
Thanks for the reminder! I completely forgotten about this one, as it was one of the first PRLs I'd tried nearly a year ago.
nettirb
