Problems After Custom ROM ( CM13-Marshmallow) on S4Mini GT-I9195
FreyamAndroid
I Previously had a Rooted S4mini GT-I9195 working perfectly....
until, i decided to try out custom roms as i was bored of 4.4.2.... I have 2 Problems....Hope u Might hELP....
(1)i tried out cm13( the latest one), it worked properly for 1 hour or so... but then when i tried downloading gApps, all the gapps were not responding.....i couldnt even open play store..the message was 'Unfortunately, google play services are stopped'
i cant even open clock due to 'Unfortuntately, clock has stopped'....
All the other apps are working fine...except for some which i have downloaded from play store( after much difficulty).....
(2) During the time when i was flashing the rom in cwm recovery mode( install zip)...i had pressed backup/restore....
now, after using cm13 for 1 day.. the storage of my phone has maxed out...and i can no longer do anything
on my phone....and when i go to the file manager(device storage)...it only shows 4 folders and there is one folder 'storage' which has a folder 'secure' in it...
when i try to open it by clicking it, they ask for a password...not knowing the password, i try to check the properties of it to check the storage used y the following folder, but when i do so, a message comes-'SOrry, File MAnager is not responding....
I------------------------------------------------------------------------------------I
I----------------------------------PLZ HELP-----------------------------------I
