[ROM] 11/20/11 - CleanROM 2.9 - GB 2.3.4 - Perfection Achieved!
Re: [ROM] CleanROM 1.3 -8/13/11 - New Features and Enhancements!
Sounds like the admins have it turned off for you. Maybe send them a PM. Its not anything you are doing wrong.
Same here...
and yes Es File Explorer would be really nice....
The sight wouldn't let me do it over my phone either. I tried through the mobile version of the web browser and the desktop version, no dice. I had no troubles when I used my computer though.
Sent from my PG86100 using Tapatalk
I am trying via the computer with no luck. I PM an admin and they can't help. Said to post it in the forum. Oh well, worry about it later. :)
I'm having the same issue with the hotspot not working on 4g. I did the battery pull and reflashed and it still isn't working anyone have any ideas
Titanium Pro is a paid app. That means no go.
I have the donate version. That means load the free version on the ROM and the license on my SD card unlocks tbe pro features already locked away in the free download.
Just flashed 1.3 but when trying to install apps from the market I get "insufficient space" error.
Before you flashed the ROM did you have your apps on thd SD card?
Not all the apps. I was trying to download the Titanium app to restore all my apps and data. I did this before when I flashed to a different ROM with no issues.
I have run into this everytime I have apps loaded on the sd card. I have some apps that do not function properly on sd so they are on the phone but most are on the sd. I have found that using the native apps 2sd causes me problems on restore. I do not know why I get issues using the native apps 2sd but I now use Titanium to move my apps to sd and it seems to work for me with no issues. When I run into your current problem I backup my sd to my computer and then wipe the card using the phone. Hopefully someone here has better advice.
Can anyone ping their phone running 1.3? So for the first time I was trying to run a couple different computer / phone apps and nothing was working. In troubleshooting I tried to ping my phone's IP address and discovered I can't ping my phone even. (over WiFi) I never tried this on stock, so I just thought I'd ask about it on here since this is the first I've tried it even. Any ideas?
I can ping my phone no problem.
I should have just rebooted and tried. But no, I went and uninstalled a few things including wifi tether, barnacle, and my avg antivirus. I rebooted, and I can now ping it. I then re-installed the antivirus and I can still ping it. Rebooted again, and I can still ping it. Not sure what exactly was blocking it but it works now.
For someone who didn't wipe before flashing, I must say I am having less issues than I expected. I said something about 4G earlier, and I'm still not sure if that is going to work when I get in to an area with good coverage or not (tomorrow night at work hopefully) And then this pinging thing which is now resolved.
All in all I am very happy with the ROM at this time.
I would like to add my 2 cents that it would be nice to have a file manager and maybe the free version of TB in it.
Glad you got it working well! I will consider a file manager in next iteration.
quick question, is anyone able to use the native hotspot via 4g? i have a decent signal at work and when i try it bounces me back to 3g. 3g works with no issues - other than slow speeds. sorry if this has been answered already. :) let me know.
Unfortunately no one has found a hack for 4G hostpost. I have heard however that it can be accomplished by using the method in this thread: http://forums.androidcentral.com/ht...7-how-get-wifi-tether-working-you-evo-3d.html Let us know how it works out.
Reactions: lfnsr
Bonembud
