[ROM] 11/20/11 - CleanROM 2.9 - GB 2.3.4 - Perfection Achieved!
Re: [ROM] CleanROM 2.0.B1 -8/19/11- Auto ROM / Theme Installer! 2
Anyway to turn off the update notification? I'm on 2.0. I also got a boot loop when trying to change kernels, but that probably wasn't rom related.
I cant possibly see how you are getting the update notification on 2.0. I have not seen it. Wipe cache and dalvik cache in recovery. That should fix it. If not do full wipe and reflash ROM.
There are no kernels compatible with the new build except freezas. HTC Has to release the source code for the kernel devs to do there thing.
Service Pack 1 for CleanROM 2.0 is now available via the built in ROM updater.
This adds Hotspot Hack by leoisright! Free wifi and USB tethering again!
REMEMBER ROM Updater is still beta and you cannot flash from the application. Download SP1 and select Apply Later. Reboot into recovery and flash zip. It will be located at /CleanROM/downloads/
Sweet! Will download and flash tomorrow when we get back home. How is it running so far?
Re: [ROM] CleanROM 2.0 SP1 -8/20/11- GB 2.3.4-Wireless and USB Te
I like the Animations and smoothness of it..
But half of my apps won't install, saying "Insufficient space" which is BS, I have over 800MB.
I wiped everything, I don't have apps on the SD.. I'm not sure what is going on.
Boot into Recovery and wipe your cache and dalvik. Then try again. First, I would get Cache Cleaner NG from the Market and it'll keep your cache cleaned. Haven't had any problems since I did that.
Hope this helps!
Kelly
Typical error message when the cache is corrupted. Not a biggie... See below...
In deed...
Reactions: kpfeiffer
Well I wiped it many times before installing the ROM. This time I wiped, installed, wiped, booted up, didn't sync google, booted recovery, wiped cache, rebooted, added google, and had to painstakingly install every app I had manually..
But that seems to have worked, at least.
What do you mean manually?
When the phone tries to download everything on its own that you had before? That was an issue. When I rebooted into recovery, wiped the cache again, and booted up again, that's when I added the google account. Unfortunately it wasn't doing the ol' auto-download of apps this time so I had to add them all myself (thank you AppBrain)
Oh, I see. I normally just log into market and install them from the website.
For some reason it didn't dawn on me about the kernels not being compatible with the update. I got the update notification to clear by just opening from the notification bar and hitting cancel. Of course it was that east. So far the ROM has been buttery smooth.
[ROM] CleanROM 2.0 Final! Now Available!
CleanROM was designed to be a cleaned up Sprint Stock ROM with some features and enhancements! This is not a heavily themed ROM! All HTC and Google Apps are uptdate as of 8/21/2011. ROM is Deodexed and based on 2.08.651.2.
Updates in version 2.0
Complete Rebuild from the Ground Up! Now based on the Sprint 2.08.651.2 RUU!
Features
ROM Updater Beta - Download ROM's and themes inside the OS! Please see post #2 for proper usage!
Performance Tweaks
Overscroll
Window Animations
Removed ADB Notification
Extended Quick Menu
Extended Power Button
Ad Blocking host file
Google News And Weather App
Google Talk with Video Chat
All Google Apps Updated
DSP manager
freeza's modified Stock Kernel
Sprint HotSpot Hack for free Wireless or Wired Tethering
All HTC and Sprint IQ Spyware is gone!
Apps
eFS File Explorer
Titanium Back up
Google Listen
HTC Flashlight
HTC Teeter​
Many colors to choose from! Show the Forum What ROM You are Using!
Donations always accepted but never expected!
Donate via Xda App or Tapatalk
Hit the THANKS Button if you like this offering
========How to Configure and Use ROM Updater=========
Start ROM updater app
Press phone Menu Button and select configuration
Select Addon/Theme Update Settings
Select Manage Addon/Theme Servers
Press phone Menu button
Select Update Featured Addon/Theme Servers and select yes
Themes by scrosler will show up, press back button 3 times.
Press phone menu botton and select Check now
Theme list will be populated
Download theme of choice
NOTE: The application is still in development! At this time you cannot automatically flash the download from inside the app! When the download completes select "Apply Later" Now use the phones power button to boot into recovery and flash the downloaded theme. It will be located in "CleanROM" Make sure you do not select Apply Now because it wont boot into recovery yet!!.
This app was developed by puertoblack2003 and was ported with permission to CleanROM!​
Re: [ROM] CleanROM 2.0 Final! -8/21/11- GB 2.3.4 (2.08.651.2 Base
Just flashed.. i noticed i don't have gps status icon anymore... is there a way of getting it back??? at least the GPS on icon.. right now i don't have any.. other than that everything seems to be working properly.....
thanks again
lol you flipped the battery back to the right direction... love it...
Is there a problem with the 4G wifi hotspot? I can get 3G but 4G doesn't work, it'll start but once I connect from laptop it loses internet access and 4G loses signal. I also can't get the wifi tethering app to work either now. Used to work before.
Also for people with the gameloft games that need their games back, I just booted stock first, backed up the 3D Games app, which has the proper link redirects. I've tried it out on multiple ROMs and sends me to gameloft wapshop site with the proper info so I can redownload my games.
I follwed ur Rom Updater configuration steps and once I hit the check now it says updates available in the notification bar in the top right and then goes away. Do I have to have display all addon/theme updates and display all rom updates checked off in the config settings?
P.S this Rom is super fast. Loving it. Thanks
Downloaded... Flashed... Everything is great so far.
As always, thanks!
Features
Performance Tweaks
Overscroll
Window Animations
Extended Quick Menu
DSP manager
Apps
eFS File Explorer
Titanium Back up
Google Listen
HTC Flashlight
HTC Teeter​
How about adding recovery as one of the power options, or adding the free quickboot app to the rom? Just makes it simple to get into recovery to flash a zip. Nice work on this one by the way, very responsive. The awesomeness continues.
Sent from my PG86100 using Tapatalk
I can't tell if it's faster or not. I think all the VERY smooth transitions/animations make it seem like that's the case. It's amazing what smooth animations do for speed perceptions.
Now that I've gotten a lot of the configuration annoyances of a fresh rom done, I'm able to enjoy things. It's looking pretty good to me. It's lame to say but I really missed overscroll :D
It's there - if you pick Reboot then Recovery is a choice
Bry
