[ROM] 11/20/11 - CleanROM 2.9 - GB 2.3.4 - Perfection Achieved!
Re: [ROM] CleanROM 2.0 Final! -8/21/11- GB 2.3.4 (2.08.651.2 Base
Loving 2.0 Frustrating to have to go through and tweak everything back to how I had it / like it.
Just my standard I have to use WiFi fixer when I connect to my Wireless N router. on my G. No issues.
Thanks!
I actually find doing that quite fun... But thats just me though, lol
Did anyone see any issues with WiFi? I have a small issue byut no one else is reporting it on XDA. They all say WiFi is fine. I think I may have hosed my baseband to a point? Or my Router is dying. I dont know but I am really frustrated :'(
Now that you mention it, yes i have noticed issues with WiFi. After some time without using it, it's like it looses response, so i have to disable/re-enable it. I am not sure if that is what you were talikng about or if it is normal. Will try WiFi fixer....
Make sure you do a good wipe. I had that issue and my router needed to be rebooted. Its working as it should be now! BTW: What radio are you on?
Re: [ROM] CleanROM 2.0 -8/22/11- GB 2.3.4 (More Colors!)
New overscrolls colors are available in the ROM Updater!
Enjoy!
Reactions: playersnoopy
Flashed 2.0 when I got back home from being out of town and looks like everything is working properly - even my issue with navigation seems to be cleared up. :) Will update if I run into any issues. Thank for putting together!
I'm not sure if this is a Sprint 8/18 update issue or a CR 2.0 issue..
But sometimes when I check my phone in a not so perfect area it says I'm on 1x. I've NEVER had it be on 1X before.
This seems to be ok if I turn off mobile data/switch to 4G and then switch back.. Then I'm on 3G.
Has this been an issue all along but the phone never reported 1X but the update changed it? Does this rom report it, kinda like how Cyanogenmod showed H instead of 3G?
It's weird that resetting the data connection can fix it, but obviously I'd rather not have to do that.
I am on 530. Why?
I saw the 1x when I first flashed the ROM, then I re-flashed the radios, updated profile and prl and havent seen the 1x since.......
Cool!
Not a ROM issue. Must be radio issue... See below...
Agreed!
Ok.. I'll flash the radios. Just drop in an .img file on the root of the device? Or is it something else? I think I've flashed radios once in my life and I'm not even sure where to get them
Noob here! Just to clarify are the free wifi tethera and 3d home screen included in the latest download? Or is it an addon that you have to flash later?
Dont do that. I will post a write up on how to upgrade radios later tonight. Otherwise, hunt on XDA and you shall find what you seek.
Free there is built in. No more 3D homescreen. Hut my eyes to look at!
How do you enable the wifi. If I use the sprint app (on 4G) it tells me that I have not subcribed to the services. I believe that 3g might work. Does this sound fimilar?
Great work and thanks for the quick response!
LH
Ahh well I took care of it already :) We're all good
Good deal!
LH
At this time... There is no hack for 4G. I know it works well with 3G. You may try the hack in the stickies that jondevere created. It may or may not work for you.
LH
OK, I see that i can use the sprint app to tether on 3G without being prompted to contact sprint to add it to my account. But when it comes to 4G I'm getting the message. If anyone has any advice please forward.
thanks
LH
Ps. The senselless rom looks great!. What are the major pros and cons to this rom?
Good deal!
Ok, on the 4G issue.
thanks
Not sure if this was covered some where in the middle of this thread, but i don't see it in the OP. How do i change the overscroll color and enable the screen on/off animations?
Actually both questions are covered in the op but I will re-iterate for your convenience.
Firs, the CRT Animations. Note they are not missing from the feature list. They will become an add on through the ROM Updater app that I built (hacked from someones work) when I have time. Now that leads me to the second question.... Themes aka Overscoll (this is very prominent in the OP):
========How to Configure and Use ROM Updater=========
Start ROM updater app
Press phone Menu Button and select configuration
Select Addon/Theme Update Settings
Select Manage Addon/Theme Servers
Press phone Menu button
Select Update Featured Addon/Theme Servers and select yes
Themes by scrosler will show up, press back button 3 times.
Press phone menu botton and select Check now
Theme list will be populated
Download theme of choice
NOTE: The application is still in development! At this time you cannot automatically flash the download from inside the app! When the download completes select "Apply Later" Now use the phones power button to boot into recovery and flash the downloaded theme. It will be located in "CleanROM" Make sure you do not select Apply Now because it wont boot into recovery yet!!.
Reactions: jrun
khalid345
