[ROM] 11/20/11 - CleanROM 2.9 - GB 2.3.4 - Perfection Achieved!
Re: [ROM] CleanROM 2.0 -8/22/11- GB 2.3.4 (More Colors!)
CleanROM was designed to be a cleaned up Sprint Stock ROM with some features and enhancements! This is not a heavily themed ROM! All HTC and Google Apps are uptdate as of 8/24/2011.
ROM is de-odexed and based on official Sprint RUU 2.08.651.2.
Updates in Version 2.1
New Google Market 3.1.3 with "+1" Capabilities
Google+
Improved Interface for ROM Updater
More Performance and Memory Enhancements
Updated to latest freeza Kernel (8/21)
WiFi Tether for confirmed 3G and 4G tethering.
Revert Status Bar Pull Down to Add in Pecent Apps
Removed Google Listen
Removed Titanium Bacakup
Features
ROM Updater Beta - Download ROM's and themes inside the OS! Please see post #2 for proper usage!
Performance Tweaks
Overscroll
Window Animations
Removed ADB Notification
Extended Quick Menu
Extended Power Button
Ad Blocking host file
Google News And Weather App
Google Talk with Video Chat
Google+
DSP manager
freeza's modified Stock Kernel
Sprint HotSpot Hack for free Wireless or Wired Tethering
WiFi Tether for Confirmed 3G and 4G Wireless Tethering
All HTC and Sprint IQ Spyware is gone!
Apps
eFS File Explorer
Google+
HTC Flashlight
HTC Teeter​
Re: [ROM] CleanROM 2.1 -8/24/11- GB 2.3.4 - Best Ever!
Can we just flash 2.1 over 2.0 or should we do a complete wipe with this update? I think I will just try flashing it with just clearing the cache and if any issues can do a complete wipe and re-flash. :)
I am also using the kernel that comes with CleanROM.
Should work...
LOL so you are using the kernel that comes with the ROM. That's what I wanted to know. Sometimes people install another ROM.
Sent from my EVO 3d using tapatalk
Its a modidfied stock kernel that removes spyware. Its the only option we have that this time. HTC will need to release the kernel source code for us to be able to dig and make it overclock, no lights, etc. Once again we are stuck waiting for HTC :(
Reactions: yibrushn
Does CleanROM 2.1 include the radios from the latest OTA update or do we need to flash these separately?
Should work...
Thanks. I just wiped the cache and flashed over 2.0. Everything seems to be working properly. Have a great day and look forward to the next update!
scott - i have read a couple of your responses over on xda that you don't necessarily like/use titanium backup. my question is what backup do you use/suggest? i have been using titanium and didn't restore anything from it when i went from 1.3 to 2.0 - low and behold my issue we couldn't figure out is no longer happening. not sure if it had anything to do with titanium, but thought i would see what you use/recommend. thanks man.
The best ROM to fit my needs something simple, fast and real stable...
No.
I don't use anything. I rarely use my phone. Its more of a dev phone. Its always recovery, lol.
But seriously, I just reload each app with a single flashable zip that I made or I keep all my apps on a storage card and use file explorer to install them one by one. I never restore any user data as its usually the user data that causes the issues we see. Ultimately its up to but here is my perspective....
If you upgrade Windows from XP to 7 I would reccomend doing a fresh install. Same thing with ROM flashing. You get the utmost clean experiences and its a great time to purge all those apps you installed and dont use and start fresh ;)
Thank you!
Reactions: lfnsr
Thanks for the info. Sounds logical. Appreciate the insight!
Sorry for the confusion, but "No" we don't have to flash the radios, or "No" the radios aren't included and we do need to flash them?
Both Yo dont have to flash the Radio and its not included in the ROM.
Had a radio flash been required I would have listed that in the OP under "pre-requisites." As well, if the radio was included in the ROM I would have listed that in the OP under "Features."
I hope that clarifies!
-Scott
i have a question for anyone that knows the steps on how to update this ROM from 2.0 to 2.1 ?? the update app that was included does not even work ..so whats the alternative on future updates when the updater app does not work do i have to download the 2.1 zip and flash it all over again like i did 2.0? if so let me know thanks ... who ever helps me will get 100 cool points lol holla at me buds :cool:
I just updated my 2.0 version to 2.1. I downloaded the 2.1 zip file. Rebooted into recovery. Wiped Cache, Wiped Dalvik Cache and installed 2.1 zip. Reboot. So far no problems.
As far as i was told, the Rom Updater will not boot into recovery yet, so its just to be used as a means to download the zip file. You will still need to manually boot the phone into recovery to flash zips. Think this is something he is still working on.
Use the included updater to download the update. Then manually boot into recovery (the updater lacks this function as of this writing) wipe and then flash like normal.
Or just download from the OP and flash like normal.
Reactions: scrosler
tuananh3105
