[ROM] 11/20/11 - CleanROM 2.9 - GB 2.3.4 - Perfection Achieved!
Re: [ROM] CleanROM 2.2 -8/27/11- GB 2.3.4 - The Best Never Rest!
@ scrosler I want to make you aware of a bug... When I charge my phone up it never hits 100% once it hits 99% it decreases to 96% and sometimes goes further down. The phone is always not in use with the screen off so nothing is using the battery when its on AC power charging. I know its the ROM because when i was stock I never had this problem can you check it out and if anyone else has this problem or anything other post so this ROM can be the best out
Ok, here are good explanations of why you are seeing what you are seeing...
Battery doesn't charge to 100%? - xda-developers
Drain while plugged in? - xda-developers
I know these are not scientific but they do a decent job explaining.
LMK If you have any questions.
hey man, i had some weird camera issues today, green stripes across the entire screen about 1cm apart when using any camera app.
Fixed after reboot. Just letting you know.
Green lines can sometimes indicate intermittently failing hardware. I am not saying this is the case but am not ruling it out either. I have monitored the threads on all 5 forums I post on and dont see any bug reports of this nature but I will certainly be looking for it now!
Let me know if you see it again...
Quick Lookup added to ROM Updater! I just cant let a reasonable request go un-answered :D
Remember to Check Now when you launch ROM Updater so it shows up. Refer to post #2 for proper use of ROM Updater!
ok, call me a newb if necessary, but what exactly is Quick Lookup?
I have been using Clean ROM for a few weeks now and have had no problems with it until I updated to 2.2 on Sat the 27. Ever since the update, I no longer receive incoming calls, they just go straight to voice mail. Has anyone else experienced something like this.
No, this is certainly not something many have experienced. I had one report on this... A complete Wipe, reflash of Radio and ROM and all was good.
What Radio are you on?
Yesterday I did a full wipe and re-downloaded CleanROM 2.2 and then updated the radio's with PG86IMG_2.08.651.2_firmware_nohboot.zip. and I'm still having this issue. I don't want to fully restore my phone and be unable to use CleanROM because it is the best ROM I have used and I want to stick with it.
Did you restore anything with TI Back up or similar programs?
Are you able to call out? Send and receive text messages?
No, I never use or even have TI Backup installed.
Yes, I can send and receive texts and make out going calls. I even tried changing the slot cycle index to 1, then to 0 and it made no difference so I switched it back to 2. I think i'm going to try and flash the Shooter_S_Sprint_WWE_2.08.651.2_Deodexed_Signed_(8.26.2011).zip and see if it fixes the incoming call issue.
Make sure you do a full wipe!
Quick question,
I just flashed your cleanrom and found that after it flashed I could only get 1x signal when I was in a 3g area. Are there any radio updates that I need to flash first? I went back to the sprint rom and it was fine in 3g.
My incoming calls go straight to voicemail now. Any fixes yet?
I cannot make or recieve calls. It keeps stating "error 16" when I try.
Quick question,
Yeah, you may try the new radio. It resolves issues like what you are reproting. And what Stock ROM did you try? And what Radio do you currently have?
Not broken so no fix will be forthcoming... See below for why.
Error 16 means Sprint hosed up your account and dis-associated your phone. This can happen after a recent unlocking. Call sprint and tell them you are getting Error 16 when making outbound calls. They will flip some switches on there side and you will be good to go!
markshane
