[ROM] 11/20/11 - CleanROM 2.9 - GB 2.3.4 - Perfection Achieved!
Bam! Whats up now?
WOOT!
Hell yeah! Congratulations, you earned it. Thanks for all that you do.
Reactions: scrosler
Re: [ROM] CleanROM 2.4 - 9/8/11- GB 2.3.4 - Just Keeps Gettin Bet
@scrosler or anyone running the rom that is still running the stock kernel that came with the rom, can someone please pull the config from kernel for me i want to have a look.You will be pulling a file from your phone so you have to be able to run commands. The commands are
Code:
adb remount
adb pull /proc/config.gz
Then attach the config.gz(might show as .zip on some windows pc's) to your post.
thanks.
Code:
adb remount
thanks.
Here is mine beezy. I had to zip the .gz it would not allow me to attach it.
Reactions: beezy
The Following Items have been added to ROM Updater...
Camera - Silent
Camera - Standard
HTC Music - Beats Auido
HTC Music - Standard
For a complete list of all available Mods in ROM Updater visit this list: Available Add Ons in ROM Updater
Reactions: kcarter17
I flashed beats audio and now the music app is gone. I used search and nothing came up, also checked under applications and its not listed.
same here my music app dissapeared
This is strange. Someone else reptroted the same thing but I cannot reproduce the issue. Let me take a look.
I tried Camera - Silent and got an error.
E:Error in /tmp/sideload/package.zip
(Status 0)
(Status 0)
A quote from the FAQ's that are on your SD card and attached to the op...
Question: When I flash a Zip file in recovery I get this error :
E:Error in /tmp/sideload/package.zip (Status 0) What does this mean?
Answer: Not much. Just means the Recovery failed to install the ZIP. Its not an error with the ROM or the zip. Its an issue with the recovery. Just try flashing it again.
i had the status 0 error as well for both the silent camera and beats zips, tried it a few more times, installed fine. except for the previously mentioned missing music app issue.
I flashed the standard one and i got the music app back.
Is anyone having install issues with the latest ver ? I wiped cache and dalvik the night before last, installed 2.4 and get a constant TWRP boot loop, ROM never boots. I then did a full wipe, same... I then downloaded another copy of 2.4 to my desktop, copied to SD, full wipe install, same thing, it just keeps rebooting to TWRP. The only way I could get my phone back was to restore an old nandroid of another ROM. This morning I downloaded 2.4 once more, full wipe, reboot, same damn thing. Ideas please
Thanks
Thanks
Must have been my SD card getting corrupted, Copied the data to another card , wiped, installed , all is well :)
I was just gonna say that. I had strange things happen like that before. During the testing of 2.4 a block may have gone bad on my SD Card. I got some strangeness when I booted up for the first time that I knew was impossible. I formatted my SD Card and pushed files back over and all was well.
Is there a way to get the stock android dialer to work on this rom instead of the htc sense version? I much prefer that one to the regular, but i don't want to lose the lock screen by going to one of the more senseless roms.. beggar being a chooser here! hah
Speaking of lock screens, I've noticed that every time I upgrade to the latest version of Clean ROM, after doing the wipe/flash/restore drill, the lockscreen is still present but any pattern I enter unlocks it... until I realized that I had a false sense of security. If I disable/reenable lock screen protection, everything works as it should.
I don't know if that happens with other custom ROMs since I haven't tried any others. ;)
No...
When you say wipe/flash/restore what are you restoring exactly? That may be part of the problem?
Well it's so minor I'd hardly call it a problem, just something to be aware of... anyway I backup all apps and data using Titanium, wipe everything (factory reset via TWRP), flash the new ROM via TWRP, then restore all apps and data via Titanium.
AnneBelleq
