[ROM] 11/20/11 - CleanROM 2.9 - GB 2.3.4 - Perfection Achieved!
Re: [ROM] CleanROM 2.3.SP1 - 9/4/11- GB 2.3.4 - The Smoothest Yet
-= New in ROM Updater =-
Smooth Scrolling Rosie! Its removes the page breaks on the Sense Launcher. A must have for total smoothness!
Two versions available, Transparent and Standard.
Enjoy!
-Scott
And hit Thanks if you like this!
Reactions: Genesiss and lfnsr
You just happened to pick the wrong time to do updates. I am updating the theme server now. I am adding a couple pieces of coolness.... Give me like 15 minutes...
OK Thanks,I'll try again in a few. Great work btw!:)
When I flash an add on or a theme from ROM updater,do I need to wipe dalvik? And I tried again and all the add on's and theme's are there, Thanks again!
Enjoy!
-Scott
Nice. Just installed the transparent smooth and really like it. Much better now!! Thanks for putting them together!
Reactions: scrosler
No you don't. Just flash the zip in recovery. It is in the CleanRom folder. :)
Reactions: scrosler
Is the new smooth scrolling thing only applicable if you are using the stock sense launcher? I'm using ADW EX. Is it screen transition scrolling, menu scrolling, app drawer scrolling or all of the above?
Yes. The smooth scrolling is a Sense Launcher mod for the app drawer.
Enjoy!
-Scott
I never realized how much I disliked the page breaks until they were removed. This rom is as close to perfect as it can be. Now if we could just boost 3G/4G,quintuple the battery life, run the dual core processers at 2.2ghz and teach the phone to vacuum, we'd have a winner! :-$
Reactions: Ramer84015
Coolness??? Drooling......
Agreed all around!
Thanks!
So is it just a limitation of gingerbread that the phone isn't fully utilizing the dual cores? Or is it able to use them now? If we aren't currently, Is ice cream sandwich supposed to fully utilize dual core tech?
That is pretty much correct. You benefit from the dual cores now, but supposedly ICS will fully support them. At least that is the way it has been explained to me.
http://www.tested.com/news/dual-core-vs-single-core-arm-what-does-an-extra-core-really-get-you/2337/
anyone know why when i dl this it keep stoping in the mid of download. thank
Updates in Version 2.4
Added: CleanROM FAQ's to SD Card!
Added: Adobe Reader
Updated: YouTube 2.2.16
Updated: Maps 5.10.0
Updated: Voice Search 2.1.4
Updated: Kernel to freeza's "StockKernel2.08.651.2update" (9/6/2011)
Updated: HOST File
Fixed: Sprint Hotspot (for real!)
Changes: Minor UI changes to ROM Updater for readability (Thanks SirWill!)
Added: Adobe Reader
Updated: HOST File
Does it require a full wipe or can I just do the cache's?
gugino
