[ROM] 11/20/11 - CleanROM 2.9 - GB 2.3.4 - Perfection Achieved!
Are you? I will not know until tomorrow. I don't have wimax at home but do at work.
Sent from my PG86100 using Tapatalk
Reactions: scrosler
Re: [ROM] CleanROM 1.1 -7/31/11- Ad Block, Native Wifi and USB Te
I just tried 4g at work. I typically have 0-1bars here. I am getting the same tonight. I think a speedtest would be pointless, the signal is so weak.
Just for fun I just ran Speedtest.net on my laptop wirelessly tethered to my 3D while connected to 0-1 bars of 4G while at work
Reactions: scrosler
No someone on another forum said that 4G wasnt working. I just needed some one to test to make sure it does connect. Thats all.
I live in Fargo... I will see 4G when 8G is out!
LOL 8G, That's a lot of G's bro. On the wimax note I sure hope it isn't a case of lost wimax keys. When they are gone their gone for good. It will be a nightmare of Amon RA vs. Clockwork Mod all over again like it was with the OG Evo.
Nah, I am pretty sure its user error in this case.
I used clockwork with no problems. I also flashed the 3d homscreen and wifi. But my question is whats so special about the 3d homescreen??? Is it supposed to be like stock or is there supposed to be a different effect??
Everything else is good thus far.
I'll check first thing tomorrow. I work in Los Angeles so I will check as soon as I get there. On a side note I sent Koush a email yesterday about the 3d not being supported through ROM Manager, I got a push notification earlier to update ROM Manager and I just got around to it. LOOK here guess what has Been added to the list :-)
I want to use this but I have a couple of questions. What Sprint apps does this remove? Does it definatly tether 4G? The Google apps are the most up to date versions. Does that include Google Talk Video Chat? Thanks.
4g tethering worked for me last night.
Just got to work. Wimax is up and running and 4G Tethering is working great :-)
Same here I did not notice a difference
You need to go into settings -> display and enable the feature. You will then see the change.
What did you do? Every time I enable the Sprint WiFi hotspot in a location with 4G coverage, the hotspot icon in the status bar shows "4G" above the icon for a few seconds, then 4G loses signal and the status icon switches to "3G." If I disable hotspot, 4G becomes active again.
On the plus side, 3G tethering with the hotspot is WAY faster and more reliable than it was with the Wireless Tether app.
Also - my battery life totally TANKED with this rom... I was getting fabulous battery life with the stock ROM, way better than my EVO 4G, even after doing the "Revolutionary" root. I'm 99% sure I haven't added any new apps after switching ROMs. Anyone else having battery life issues?
I have not noticed much change in battery life. Maybe a slight bit better. I have been using it more, my usage pattern changed after making it harder to judge.
My battery is exactly the same, no better no worse. I didn't notice 4g disappearing but will look for it tomorrow
If the battery life tanked with the ROM then you are doing something different than with stock ROM. I took about 100megs of applications that were eating away at the battery and connectivity of the device. This alone will give you slight improvement in battery and notably better memory mgmt. Im not saying you don't currently have poor battery life but I am saying its not the ROM that is causing it.
Edit: There was one other person noting decreased battery life on XDA. I told him pretty much the same thing I told you.
Yep, you should see ever so slight improvement in battery due to 10,000,000 stock spyware apps not running and logging you and everything you do.
I agree it seems very very unlikely that anything is "wrong" with the ROM. My question was more along the lines of asking if anyone knew of some setting that might get set to the "wrong" position after a factory reset / flash new ROM / restore apps & data cycle, some setting that might significantly affect battery life (I do have "always ON data" disabled.)
Ok, I see....
Hmmmmmm..... Do you have accounts and sync syncing a bunch of accounts like Facebook, Twitter? How about battery saver in power settings? Are you syncing weather? I dont know. I am just throwing out random thoughts...
Ok, I see....
Yeah I always disable those syncs and set the power saver to very conservative (battery preserving) settings... somehow I think I'm missing something subtle. Anyway thanks for the suggestions.
I am about to flash this ROM but before I do what is the best app for backing up my apps?
s1atoshi
