[ROM] 11/20/11 - CleanROM 2.9 - GB 2.3.4 - Perfection Achieved!
Re: [ROM] CleanROM 1.1 -7/31/11- Ad Block, Native Wifi and USB Te
Thanks scrosler! The wifi hotspot works great and I gained around 70MB on boot. A clean device and hotspot are all I really care about so this will do just fine for a long time.
Good deal!
Any chance that it's possible to connect your Evo 3D to an ah-hoc network with this ROM?
You mean, connect the Evo 3D to an ad-hoc? I don't know, never tried. I would assume no because Nativity its not supported by Android and I made no changes to implement the function. I do believe its a simple change that I could look at if you need that function? Im always open to suggestions!
is it just my phone or dose anyone else's phone not want to connect to wifi networks?
works here
Thanks to the Devs for the rooting process, didnt take any time at all and no hitches with h-boot version 1.4.
my only question is are you able to do OTA updates ( PRL,Firmware, Profile, and HTC software) under system updates within settings menu. one of my buddies said that if he hit those on his optimus S it would really screw things up after it was rooted and custom rommed.
Any Ideas tech Devs?
Never EVER EVER accept an OTA update while rooted. There will be rooted versions of the update for you to flash shortly after the OTA update is pushed.
Again, please dont accept OTA's. Seen it happen way to much.
Reactions: scrosler
Yes, if you could add that functionality I would be one happy Rat. :) I didn't even realize until recently that native Android didn't support it lol.
Re: [ROM] - CleanROM 1.0 - 7/29/11 - A Clean Sprint Stock ROM!
Yeah, it should run smooth, very light modifications at this time until I feel this puppy out some... Although Market did force close on me once but never again. I think that is more market related and why google has not released it "officially." I have also seen the complaints on many other threads in regards to but not related to my ROM; Im sure its a Market thing. If it were to get annoying or bad I can always revert to official released.
Ok, forgive me for the noob question. I come from the Optimus S forums. It was rooted and had a custom recovery and ROM.
When I flash this, do I need to wipe everything like we had to on the Optimus or just flash? This phone is so different and I don't want to brick it, so I'd rather ask and make sure than guess.
Please keep the flogging to a minimum. ;-)
Thanks, Kelly
Just out of curiosity i had to call sprint and have them fix my account so that i could recieve texts and calls. if i reflash to another rom or whatnot will i have to go through all of that junk with sprint again or will i be set? was that call to get the fix from them a 1 time deal after rooting?
You should not have to can again. That was the byproduct of the s-off process.
Thanks, Kelly
Hi! I remember you from over there. Jondevere posts over here too.
I haven't flashed a ROM on this phone yet either and am considering this one. I do recall that when I flashed Sprintlovers on my 4G I only wiped davlik and cache. I would like to know the answer too. I would think since it is a stock ROM and you aren't changing kernels that would still be the case but I'd like to be sure.
Edit: Just read on page 1 that you have to wipe data and do a factory reset.
Yep, what he said x100000000000000000!!!!!!! DO NOT ACCEPT ANY OTA UPDATE! I think I will pull that ability from next revision!
Will do.
Thats what I am thinking. Some people had issues, some didint.
Its highly encouraged! If you don't, you can always see what happens, At least wipe dalvik and cache. Just dont post any bugs until you have wiped all.
Reactions: CarrieK
Any chance on getting the CRT animation thrown in here?
Im torn... I have it done but... It starts adding mods to the ROM that detract from the official CleanROM motif. If I ddont add it to next rev (which will be out soon) then I will post it as an add-on.
smithjonathan22
