[ROM] 11/20/11 - CleanROM 2.9 - GB 2.3.4 - Perfection Achieved!
Re: [ROM] CleanROM 2.5 - 9/18/11- GB 2.3.4 - It Just Got REAL!
Gingerbread Icons added to ROM Updater!
They are available in all overscroll colors with or without transparent pull down!
Enjoy!
Reactions: tnadawg89
Anyone having problems with the stock music app doing random things like calling people on the call log or suddenly stopping in the middle of songs? Starting to happen more frequently. Does it with and without headphones plugged in.
Sent from my hacked up 3VO!
Cant say I have ever heard of the music app making calls.
There's also a thread open in the general section...so I know I'm not alone! ;)
Yeah, like I said, Never heard of the music app making calls. lol
From the description of the problems in that thread it could be an issue with the 3.5MM jack. Its not software, I can tell you that. But..... I have been known to be wrong in the past :(
the gingerbread icons arent showing up in rom updater for me
I don't think it's a software problem either because some of those guys are running stock. Oh well, guess ill just have to be aware of rouge calls ;p
Try a newer pair of headphones I had the same issue I was using an old pair of earbuds. Then I recently bought a new pair problem solved
Reactions: radiation0512
Sorry if I missed this somewhere previously...
I've installed CleanROM 2.5. When I check for updates in ROM Updater, it lists Clean ROM 2.5 as an available update and says it requires web site download.
Isn't that what is already installed? Or are there updates from time to time, but the version stays as 2.5?
Thanks for your help!
Very possible.
If you are on CleanROM 2.5 then there are no updates. Thats for people who are not on CleanROM 2.5. Unfortunately the program doesnt do a good of discriminating between versions installed and available.
Yeah...that was my next thing to try. Thanks!
Let us know how it works out.
Reactions: wwannarka
Yep. It wont show up until you upgrade to 2.5.
ok upgrading tonight. i have to say, i am impressed by the dedication you have to the users of your ROM. so thanks again for the incredible support!
Thank you and Your Welcome!
So I am considering this..... A few questions:
How.much time(approximately)will it take to get set up?
Will I still get Sprint and HTC updates?
Will it fix the problems I am having with the GPS widget on my 3VO?
Will I still be able to use the same theme I am using now?
Does the adblocker work in games too?
My main interests are better speed and battery life, less clutter, and more user-friendliness......
Thanks!
10 minutes
No they are blocked for safety. You never want OTA's on an custom ROM.
I dont know what issue you are having so I cant say. But I can say that no one has reported an issue.
I dont know what theme you are using now. Its 50/50. Depends on who made the theme, how they made theme, what base they made the them from, what files they themed, etc
If you tell me the theme I can test it.
Depends on the game. Some games skip the host file and do some sort of fucnky direct method to get ads. IF you tell me the game I can test it.
Thanks!
You will get all that with this ROM.
-Scott
joelkmason
