[ROM] 11/20/11 - CleanROM 2.9 - GB 2.3.4 - Perfection Achieved!
Re: [ROM] CleanROM 2.5 - 9/18/11- GB 2.3.4 - It Just Got REAL!
I had followed this method when I flashed:
xda-developers - View Single Post - [ROM] CleanROM 2.5 - 9/18/11- GB 2.3.4 - It Just Got REAL!
I guess I may just not be wiping the device correctly, I just used the simple factory reset option in cwm.
That's weird because it looks like I did it right, I'm still s-on though, so how would I flash this base kernel that didn't get flashed? I'm not seeing any links on that steps page that seem to help me.
Ignore my ignorance :)
I got it working, man do I feel stupid.
Is there any solution to the "out of space" market problem?
I'm full of problems today.
This has happened to me on a past version. What worked for me was to re-download CleanROM and flash with just wiping cache and dalvik.
So you think it is not supposed to loop? Or that the loop does not work with this mod? It seems like it would supposed to loop.
When the phone was stock my weather live wallpaper didn't loop. It has always ran the animation once, then a still screen. That's been my experience anyway.
No need to feel stupid.
The solutions can be found below....
I think a cache and dalvik cache should suffice. But a re-downlod never killed anyone.
At this time I see no issues with any live wallpapers. If someone is seeing an issue please be specific and I will take a look.
-Scott
My weather live wallpaper has never looped either that i can remember. Pretty sure it just animates once when you turn the screen on / unlock it and then its a still. I always assumed they did it to give you a little bit of animation but also be a battery saver.
Scott,
Feature Request: If its easy to do, can you add a toggle for Airplane Mode in the quick settings pulldown?
im on 2.4 and love it, tried flashing 2.5 last night and my WIFI wouldnt work. everytime i tried to turn on WIFI it said error.
back on 2.4, everything fine.
i did do a full wipe, factory reset, cache, dalvik
I am assuming you are using hboot 1.5? When you went to my website to download the ROM did you read the article on hboot 1.5? I wont go into detail right now but read the article and you will understand what is going on.
If you are not on hboot 1.5 then something I have never heard of is going but its highly unlikely.
LMK!
-Scott
EDIT: I made the title stand out more so you should be able to see it easier. And this is not an issue with ROM, its an issue with HTC Unlock method.
Reactions: laggedmkiii
Hey Scott,
I think you said you were going to take a look at the HDR mod to see if it was working for you, if thats the case, while you're looking at that, can you also take a look at the new 1250 ISO setting?
I angled my camera under my desk where its low light, i then cycled thru the different ISO settings starting from 200 and working my way up each one. Each ISO setting i was able to clearly notice a bump in the light that was let in until i went from 800 to 1250, the screen didn't do the flicker change like it had for each of the other ISO's. Just curious if it wasn't working or if the difference between the two is so small that i couldn't notice a difference. I'm thinking thought that it isn't working based on how noticeable every other setting change from one to the other was.
Thanks!
Hey Scott,
Thanks!
Im starting to think the mods diditn take... I may have to take another look at the whole thing. Maybe I did something wrong but I was following the thread to the 'T'. Not being well versed in photograph... I really dont even know how to test. Maybe you can PM me what each specific additional function does and how I can confirm they work? That way I atleast have a clue. If its something you are willing to help with that would be AWESOME!
Thanks!
-Scott
Thanks!
-Scott
Scott
I may be able to help with the camera mod.... Just let me know how..
any word on the beats audio (and being able to configure other than default "pop" setting?)
Is there an app for beats audio? I just have the normal music app.
Never mind, found the beats audio, it's just an icon within the normal music player. Also if you want to change off of pop, you need to plug in a headset. then you can select "Equalizer (headphones only)" then you can change it off of pop.
Yep! Sorry, forgot to mention that, lol :-[
LMK!
-Scott
I am on hboot 1.5. I will read the article now. thank you for the reply! love the ROM btw and really appreciate the hard work that you have put in to this. Thank you!
Reactions: scrosler
Thank you, let me know if you have any issues.
francomattia
