[ROM] 11/20/11 - CleanROM 2.9 - GB 2.3.4 - Perfection Achieved!
Re: [ROM] CleanROM 2.6.1 - 10/5/11- GB 2.3.4 - Rockin' the Beats!
For some reason your download site keeps thinking I am trying to pull multiple downloads? Keeps saying yo slow down! Any ideas why?
I think I figured it out! There was a guest limit of one download every 60 seconds. Some sort of DDoS / flood control. I think I fixed it... Let me know!
Is it just me or is the volume in the headset a lot lower in 2.6?
Sent from my PG86100 using Tapatalk
No, its lower. You can thank Beats for that.
I think it would be! But just remember, the .so is rendered useless without an application to use it ;)
Thanks Scott! If its useless without the htclogger.apk file and assuming no other app can make use of the .so file/info, then I will probably just leave it.
I did a full wipe as instructed...WiFi tether causes super user to fc when I launch the tether app.
Thanks
Scott? is your website down?
Yep... Doing a DNS move right now. Hoping ti will proprgate in an hour or so...
Ip is here: 184.107.161.190
rock and roll brotha, every thing looks good again =P
Ninja edit: 2.6.1 doesn't appear to be uploaded =D
Yeah, I totally hosed up the IP address. I am uploading to a mirror now....
Nevermind!
Site is back up!
You may have to clear your DNS cache!
Re: [ROM] CleanROM 2.5 - 9/18/11- GB 2.3.4 - It Just Got REAL!
The biggest difference I think there is is that with true S-OFF you can reboot from the and load the Recovery from the hboot, once in recovery flash away.
With 1.5 you need to reboot via cmd (from yer PC) push and call on the Recovery through fastboot in order to get a true kernal flash. I experienced this first hand when I first flashed to CleanROM calling on recovery direct from the phone with no wifi and a couple of other things... Did it right and it's all good.
Trust me.... I'm a Desert Hydrologist. ;)
Re: [ROM] - CleanROM 1.0 - 7/29/11 - Clean as a whistle!
Prerequisites
  • Custom Recovery installed-----how do you do this????
  • hboot 1.3 / hboot 1.4 / hboot 1.5
  • Note to hboot 1.5 Users you will loose WiFi and 4G unless read the hboot 1.5 notes HERE
How to Flash
  • Download ROM and place on the root of your SD Card----how do you place it on the root of your card????
  • Boot into recovery mode
  • Wipe Data / Factory Reset
  • Flash ROM
  • Reboot and enjoy!
Change Log
How to use ROM Updater!
  • You must read the instructions HERE to use ROM Updater!
Thanks to:
  • mwalt2 - Kernel
  • theANDROIDosX and dandan2980 - Beats Audio Mod Help
  • Beta Team: brol1k, F_K3NT_D, Newboyx, lrod0175, AZ FadeOut and many others!
I added some ????s. I have unlocked w/the hboot 1.5 method and am eager to get down to business.
Glad to see you were successful rooting your 3d. You should already have a recovery - it is a step in the root process. Did you install a recovery? Once you download the ROM, just put in on the SD card - not in a folder. Then you boot into recovery, wipe cache & dalvik, do complete reset and then flash the zip of the rom. Re-boot phone out of recovery and you are all set.
Won't let me update from SD card for some reason......
Edit: says. E:can't open /cache/recovery/command
And when I try to update SD card, it says: invalid command
....then reboots. And not into cleanROM
this need to come, to the Epic samsung!!!!!!!! screw the evo!!! no offence evo fans, evo is good but we need it to support ALLL androids!!!
What needs to come to the Epic?
Really? You have a Samsung Epic and your first post on android central is in the EVO forums and you say "screw the evo!!!" ? ha
:confused:
kingteekay
