[ROM] 11/20/11 - CleanROM 2.9 - GB 2.3.4 - Perfection Achieved!
Re: [ROM] CleanROM 1.1 -7/31/11- Ad Block, Native Wifi and USB Te
Yes.. i figured that much... i just did it.. we will see how it goes...
thanks again
I am S-OFF, and still on the factory ROM. I had WIFI router issues on my new N router, but don't think I had them before on m old G router. I had to download an app from the market called WiFi fixer. it insures that I stay connected to my WiFi. Without it I had the same symptoms as you. However I could disable wireless and then reconnect to my WiFi and it would work. A couple times now I had 3G/4G connectivity issues. I think did have to do a quick reboot to make it work.
I re-flashed, and so far issue is gone, i am keeping an eye on it. I think it might have been something i restored using titanium, which i wont use anymore because the only thing i really wanted from it, was to restore my mms, and the last time it didn't.....
Glad its working for you now.... Also If you sync device with google and let it make back ups it will sync your MMS automagically!
Really?.. So far ihave been able to sync everything but mms and txt with google... I don't know why..
Will keep reading..
Thx
Will keep reading..
Thx
Strange, mine has done it. Wonder if it sees it as a different device somehow?
New to Android and Rooted last night. Flashed this ROM this morning and really liking it so far. Thanks for your time and have a couple beers on me. :-$ on the way.
Sir, your donation is GREATLY appreciated!
Thank you!
Reactions: lfnsr
Sorry for this question...but i am a noob and i am just started to learn flash/root, how do you wipe caches? and what does this do?? Thanks in advance
Every is a newb... ONCE! lol
Wiping cache / dalvik /etc is done in recovery mode. It just cleans up the junk from the old ROM so the new ROM doesnt have any conflcits.
If you do a Wipe / Factory reset in recovery it will wipe everything that needs to be wiped for a completely clean install (the ROM wipes /system)
You can try to upgrade ROMS (not receomened for optimal compatibility and performance) by just wiping the /cache and dalvik cache and then install ROM. This generally lets you keep all your apps and settings because /data is not wiped.
Also, some mods require you to wipe /cache and dalvik because they change some core system files. Those mods will be labeled as such before you download them.
Hope that answers it. If not let me know.
Reactions: reliancejr
Basically... go ahead and do a dirty flash of the update.. but if anything goes wrong.. thats the first thing that is gonna be told. DO a clean flash...
hi i just installed cleanROM and now when i am trying to download my apps it downloaded like 3 and after that it says there is insufficent space when there is .9 gb available internal according to settings.
What recovery and what version do you have?
twrp and by version do you mean of twrp or cleanROM. i am using cleanROM1.1
update: i just tried to reflash cleanrom and it gave me the same error.
Re: [ROM] CleanROM 1.2 - 8/12/11- AdBlock, Native Wifi and USB Te
Version 1.2 is now released!
Updates in version 1.2
Added CRT Power On / Power Off Animations
Added Transparent Pulldown
Added Additional Quick Settings
Added 4-in-1 Shutdown Menu
Updated Adobe Flash
Added Gtalk with Video (WiFi or Network Data)
Im at a loss, I tried ver 1.1 and the new ver 1.2 and had no issues at all. I just installed 10 Apps.
Maybe try downloading new version, do fresh complete wipe / factory reset.
Sweet! Downloading now.
Right on. Downloading now. I just flashed 1.1 yesterday and had everything set back up. :) Oh well, now I know how to do this. Appreciate your hard work getting this put together.
Downloaded flashed and working like a charm! Great Rom! :)
I am getting an error in QIK trying to do video chat. I have done a wipe/factory reset twice and re-flashed the ROM but I get the following: "The application Qik Video (process com.qikffc.android) has stopped unexpectedly. Please try again." Then it force closes. Any ideas? All the other functions seem to be working great. LMK. Thanks for the help.
junkchandu
