ARCHIVED: [ROM] - 11/6 - sROM 1.2 - Beauty and Performance Redefined!
Status
Not open for further replies.
Re: [ROM] - sROM 1.0 - 7/29/2011 - Speed, Style and Functionality
It SHOULD be. Been tested with Xiona and amonRA. Can you flash any other current ROM on this forum (CleanROM, ShellROM, etc)? If so you can flash this ROM. It uses amend scripting.
Not sure, I will take a look at it tonight. If anyone else reading this can test B/T that would be great!
Can you further elaborate on what your question? You want to keep your current ROM /Data/App folder?
if its any help, I keep getting a force close when I try to pair my headset. I have three if them and I get the same thing each time
Reactions: scrosler
What a pleasant surprise, when you mentioned this in another post I thought I'd be waiting awhile to see it. Downloading now.
Reactions: scrosler
Thanks! I will check it out as soon as I get home and notate as a known issue for the time being...
Could someone with a BT headset do me a HUGE favor while I am stuck in the abyss??? (I will owe you big time!) Can someone flash CleanROM 2.1 and tell me if you have any blue tooth issues? That would help me tremendously!
If I wipe data will it not delete all my apps and data from them with it?
I can do and will let you know. Give me a bit
Thank you much!!!!!! I am just trapped at work right now and want to have a heads up when I get home as to where to start looking. This will cut down on time tremendously. I dont use bluetooth so...
Ok got CleanROM installed and got my headset to pair. So I hope that gives you a starting place to look at. Will be sure to install your ROM back on here once you got it fixed. It's a great ROM from what I have seen so far. Thanks for your quick responses and your willingness to look at the problem.
Reactions: scrosler
Is there goin to be any apps to sd on this rom
Sent from my LG-LS670 using Tapatalk
Possibly later. If you are willing to beta test it for me I will work on it but....
Thanks dude, owe you big time! I will have this blue tooth issued fixed later tonight!
Any time buddy hit me up on pm.
Its almost done from downloading goin to test for bugs
Possibly, I have not tested them. Good chance they would. You could always try and if they dont, just reflash ROM.
i just got this phone today, coming from a epic i broke on accident.
im fully up and running, with this rom.
but im having issues.
things are not updating, like fancy widgets clock/weather are not updating, and i also installed battery monitor widget regular and pro, and they are also no updating..
what gives?
what gives?
Whats not updating correctly? Use Fancy Widget as an example.
EDIT: Just tried fancy widgets and it seems fine to me. I will move on to the next app, battery monitor widget regular
EDIT2: Just tried battery widget monitor regular and it seems fine. Explain in detail what you are expecting and what its doing please and I will try to figure this out for you.
Reactions: intheb0x
well for both apps, the time would go on, but the app would be stuck at that time i opened it as a widget.
i rebooted the phone after installing them, they are back working.
i will continue testing them and let you know what if any other issues arise.
great work btw.
great work btw.
Good deal man! Good deal! Let me know if you find anything else.
Reactions: intheb0x
since im used to running 1200mhz and so on with my previous phones, what cpu speed do you recommend?
i did the max and my phone restarted...
will jumping up at all from the set speeds show any benefit?
Personally I would leave it at default 748MHZ. I know a guy that runs his at 806 and has no issues. He also runs the low end at 122MHZ. I have not pushed it that far but as you know each device will act different when it comes to overclocking. Give 806MHZ a try and experiment from there.
alright, thanks for the insight.
while playing with it, 806 seemed to make my phone laggy..
after messing with it, im currently at 825 and it seems to be the sweet spot.
the phone flies, will keep testing.
i got the phone for about a month.
Reactions: scrosler
Yeah, I am sure this thing feels way different after running an Epic 4G!
Status
HourFromNow
