ARCHIVED: [ROM] - 11/6 - sROM 1.2 - Beauty and Performance Redefined!
Status
Not open for further replies.
Re: [ROM] - sROM 1.0 - 7/29/2011 - Speed, Style and Functionality
Yeah, I am sure this thing feels way different after running an Epic 4G!
im originally a evo guy, then the epic, and now the optimus.
while its not either of those, its well worth its price,feels solid and well made.
my next phone will probably be the photon or sgs2.
but until then ill play with this lil guy..
im satisfied with it, this rom really helps it along, its going to be my daily driver during the day and at work.
i see it having no problems doing what i need it to do.
shame i broke the epic today.
I'm installing 1.0a right now and let you know in a second.
Reactions: scrosler
Just flashed to the 1.0a file, very nice i might add. no issues so far. bluetooth wifi everything works so far. keep up the good work :)
Reactions: scrosler
Thanks alot for confirming that! Much appreciated!
Question
where can i find things like different battery gauges and such?
since there is no apps/themes/mods section here, its kinda spread all over..
Question
I got portions of the themes from files on XDA (with permission) and the batter gauge on UOT. Then I hacked it all together on the framework-res.apk.
If you know how to do that you can make your own theme. Its not hard.
I also believe Nick7's ShellROM themes are compatible with this ROM. I'll try to find the link...
EDIT: Cant find the link... I am sure someone has them...
If you want to start off on a stock Froy ROM with no theme you can also check out my other thread: http://forums.androidcentral.com/lg...-2-1-7-26-overclocked-ad-blocked-hotspot.html
I was able to pair my headset but not connect it. Any other ideas?
Hmmm.... Laguna said it worked for him... I wonder if he tried to connect?
I am assuming you rebooted after fresh flash...
EDIT: I just tested blue tooth file transfer and it worked perfect for me. I dont have a headset to play with though...
I don't get it either. I did do a reboot and I show I can pair. My headset even tells me that the phone transfers successfully, just won't connect to use.
Can you try a file transfer from PC or another phone?
I have a question im using reborn rom 2.2.4 which i do like. What do i get using this rom over that one. How is this one better then reborn. I'm really thinking about trying this one out.
I used Quadrant standard to bench mark reborn i get around 536. what is this rom getting.
thank you for your reply's
You don't have to solely rely on QS, I got 600 on mine with Reborn Rom...
Reactions: scrosler
Best rom ever for my Optimus s, and i have tried them all, keep up the good work.
Reactions: scrosler
I was having an issue with the stock music player and google music battling eachother. Froze the google player and all seems at peace now.
Yeah, thats strange becuse I removed the stock Music player. Atleast I thought i did. I will look at it later.
FYI: I updated the links because Dropbox has a limit on downloads and I guess I exceeded! Who know!
You can remove the stock music player from system/app/ if scrosler forgot to remove it. Problem solved so no need to freeze your Google player. ;)
Sorry guys still no time to look at that yet. But yes, you are correct. I have to head to work for a half shift then I will get looking at that issue. Knowing there is a potential bug is annoying. I have been doing E3D stuff all last night and this morning.
ok i wont solely rely on QS but what is it that makes this rom better then the other roms on the board.
Im not sure if anyone has brought this up yet, but it would be better if you added Reboot and Recovery to the power menu, and then you can remove Quick boot. Just my thought but once again awsome rom.
Status
Greenfid28
