ARCHIVED: [ROM] - 11/6 - sROM 1.2 - Beauty and Performance Redefined!
Status
Not open for further replies.
Re: [ROM] - sROM 1.0 - 7/29/2011 - Speed, Style and Functionality
kingdavidbaker,
FYI, that blueTouch I cooked for you to use with Shell Rom, should work with this rom too. Just make a Nandroid first, since I have not tested it.
Yeah I plan on trying that out but i've been lazy lol. I do like the basic black theme of sROM though so a black notification window with an animation would be dope :)
kingdavidbaker,
Can someone post a screenshot or a link to the file so I can take a look at it? Just curious at this point.
Well the one he made for me is the exact same as the blue touch theme for ShellROM only the notification window is flat black instead of transparent. Pic of notification window below.
So picture that without the toggles and with a flat black background. I just don't really like the transparent window as it makes the screen too busy and the lil android in the bottom right corner is awesome. Also the more black displayed the better your battery life. Granted its a small difference but every lil bit helps lol.
Ahhh... I see. Ok, Thanks.
If creator is willing I can port the theme over to sROM as a flashable zip.
Well he was saying it should already work as it is....and that would include all themes built for ShellROM. I'll try it now and see if it functions. But I like your stock black theme and would continue to use it if I could spiff up the notification window. I plan on learning how to create themes anyway so I guess I'll figure out how to edit that at some point.
I can confirm the shellROM theme I have works perfectly fine with sROM. It works perfectly fine using both the froyo launcher and the launcher from Reborn.
Reactions: jstntp
BEST ROM OUT ! It's so fast :) Please keep 'em coming! Thanks :D
Reactions: scrosler
Hello everyone, is anyone else having sending mms messages with this rom? My battery almost died trying to send a mms!
Nope, MMS has been tested to work perfect, both send and receive. tested it myself :cool:
Did you install any apps that change the default MMS by an chance?
I don't know if anyone else is having the same problem but the Android market keeps fore closing. It normally begins after the third reboot (first after flashing the rom). Any ideas on how to fix this?
BTw other than that no problems and love the rom!:)
I noticed it did it once and I think it was noted once in the thread before. Its only done it to me twice now... Since I put the ROM out. It also did it two times on my Evo 3D (same APK). I think the APK may be a bit too early for release, hence Google has not officially pushed it to the devices. If it becomes a problem I can always revert it back to the official release from Google.
Please I would appreciate.
I'm at work now, you can use ADB to disable and maybe someone could upload the most current legit version?
Otherwise I will try to get something for you tonight or tomorrow. I have a couple Evo 3D ROMs I am working on so this device doesn't get the air time it used to (pun intended, lol).
Lol:D I'll keep an eye out for the update thanks
Thanks for the reply, been using handcent and everything seems to be working fine now.
this rom is crazy fast! i love it!
i used some techniques to make it work for my optimus v found in our forums
the only issue i've found is sending pics/audio files gets stuck, normal texts work
do any of you have a suggestion for me to fix this?
i know this is an "s" rom but i wanted something new.
i know my problem isnt related to the rom, its with my "porting"
any help would be much appreciated
Im sure we could figure it out... Hmmm... There was a resource on the S forum that shows how to go from a V ROM to an S ROM. If I/we/you could find that we could just reverse engineer it.
Because this is not directly related to the posting here lets discuss this in PM. I dont want people getting all confused (including myself) about whats going on.
Thanks,
Scott
Reactions: arhtard
for those of us with issues with bluetooth, what do we do?
i dont want to have to wipe all over again?
What version are you on? 1.0 or 1.0a? AFAIK the Bluetooth issue was fixed in 1.0a.
the original.
should i download 1.0a and flash it then restore data from a nandroid?
i would hate to have to start fresh again
Status
squirtman
