ARCHIVED: [ROM] - 11/6 - sROM 1.2 - Beauty and Performance Redefined!
Status
Not open for further replies.
Re: [ROM] - sROM 1.0 - 7/29/2011 - Speed, Style and Functionality
anyone have a mirror of the download? i was downloading it and it said it would take 1.5-2 hours for the download!
check your speeds using speakeasy.net or speedtest.net
sROM 1.0 (mediafire)
I think GoDaddy webhosting is having issues. I cannot even open my site at all. Sorry.
EDIT: That was quick.... Its back up and at full speed.
I'm enjoying the ROM so far, but experiencing a weird annoyance:
Whenever I reboot, I lose my entire call log, SMS data, and home screen app data (all apps except for the Sense widget and Market are gone). I have rebooted twice, and this happened both times, forcing me to re-restore backed up data and re-arrange icons on the home screens.
Any ideas? I made a Nandroid backup and wiped everything before flashing.
Thanks
Thanks
Strange... I will try to replicate....
Thanks
I just tried everything you noted and could not replicate the issues.
Here is what I did....
1. Downloaded ROM fresh from site
2. Copied to SD
3. Rebooted to recovery
4. Wiped data / factory reset
5. Installed ROM and Rebooted
6. Added wigets to home screen and made call.
7. Rebooted and verified call log was present and widgets were as they should be.
You didn't try to restore anything from back up on top of this ROM did you? Like did you try to restore anything using titanium back up?
2. Copied to SD
Yes I did, actually - I restored all my Apps and Data with Titanium Backup. Should I not have done that? If so what's the better alternative?
Thanks for your help!
Battery life is superb.
IM not sure, I always recomend a fresh install of apps after a fresh install of a new ROM.
Indeed!
My phone keeps trying to roam for some reason. My other phone (evo) with cm7 does not roam in the same room. I updated profile and prl and will see if that works. in the phone settings where it status is network supposed to be unknown?
I only restore app data with Titanium Backup, downloading my apps from the marketplace every time I do a fresh ROM install. It doesn't guarantee that you won't have a rogue app screw something up on your phone but it greatly reduces the chances.
I want to say that I really like this rom. It works very well on this phone. The best one I have tried. No plans to change.
The only time I have that issue is when its for a real reason.... Not sure why here because the baseband is not touched....
Thats what I think too!
Thank you!
I did a fresh flash of the ROM, and then did exactly that. Now everything is working fine. Thanks again for the help.
Good deal! Glad you got it going well.
does anyone have a problem waking the phone from sleep sometimes?
That is a problem that this phone has had on all roms, even stock. I still get it sometimes with Reborn. For some reason a dirty flash (wipe nothing) of the Rom again seems to pretty much fix it.
Reactions: bdionj
Okay, I have my Optimus S rooted with z4 root, and I have Xionia custom Recovery, but I have Baseband Version V9. Am I able to update it to VD being rooted and All, is there a safe way to do so?
Status
richardgroover
