[ROM][4.19.2011] Das BAMF 1.5
hmm...this is the second time I've gone in and flash was uninstalled. Redownloaded Flash 10.2 from the market and it's working fine on das BAMF 1.2 w/1.9 kernel
Question, Did you have any problems with WIFI errors with Das 1.2 and Kernel 1.9?
I tried the 1.9 & 1.8 kernel today and had Wifi errors with both. Back to stock rooted kernel. =(
Im running Perfect Storm 1.1 ...if I want to try 1.3, can I just do a Cache Wipe/Dalvik Wipe then just flash this or do I need 1.1 then 1.2 over it followed by 1.3?
nope. It actually seemed to get rid of the wifi issues from previous kernels (including stock) where it would show connected but data wasn't coming in or out.
Haven't run it through a regular days use but 1.3 is smooth like butter so far.
Yeah 1.3 is running pretty smooth even it has been a few hours. That kernel is very stable as well. I'm sticking with these guys for a while. Thanks again.
I just rooted my phone if i wanted to install this rom can i just install 1.3 or do i have to install the first release and then flash the other updates on top of it? Also can i install the kernel in rom manger along with this rom.. I would flash roms/kernels all day long with my OG droid but after reading and seeing people get stuck on the cloud screen I wanted to make sure i do the correct thing. Also i see roms made for .9 ver. and im on .6 so do i need to flash a .9 ver rom first? Sorry for all the noob questions
well darn. Installed 1.3 and i'm back to the quirky wifi where it thinks it's connected but won't do anything. Doesn't seem to like the linksys router at work using WPA w/TKIP.
+1....also, being that I'm using Perfect Storm, is the kernel by itself, compatible if I want to overclock?
Loving the new transition effects. Also I really like the Market's new skin. Great job on this one. Between the effects and the subtle over clock this thing feels flawlessly fast.
No issues so far.
Going to charge her up and see how the battery drains.
The personalize button doesn't work with this rom. Is there something I need to do to get it to open? It does nothing when I press it.
Just installed and everything seems to be working great! Thanks again for another sweet update!
I was wondering if the powersaver profiles are automatic or if we have to set those up with set CPU?
Edit: what's a safe temp and what's considered too hot?
Sent from my ADR6400L using Tapatalk
How do you get the personalize button on the bottom to launch. It does nothing when I press it. Is this an issue with this rom?
The guy above just answered this. Read his reply to your post.
On page 1 there is a link to the LauncherKey app. Download and install it.
In setCpu you set up your own profiles to set your limits
Well the battery safe limit is 60 celius if i read right. not sure what the CPU is...
I installed the app but it still doesn't open the personalize button. I long press and can get it that way but it would be nice if the actual button would launch it. Seems thats the only thing that doesn't work on my phone.
After you download the app open it up. You basically bind it to a function using that app.
StevieD49
