ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
Performance is A LOT better. I did get a forced reboot though, but im not sure if that was from my over clock or not. Really good work on this tdm, it is a GIANT step, I owe you a drink.
Also it seems enabling WiFi breaks the 3G fix(CM9 build).
I don't even have WiFi... It connects but then there's no internet connection.
Any clue on the WiFi though?
[EDIT] I take that back.. I think the 3g is a bit borked when trying to use WiFi.
Well I have no luck with WiFi and 3g is just dropping on and off now.
Reactions: kenbrasensei
@tdm - Thank you for Alpha9. Other then a borked wifi connection, which isn't a problem, I'm gonna be using this as my rom for the forseeable future. Thanks again. :D
Reactions: tdm
s far as the wifi goes there's a couple of things one: wformat system cache data and boot once not again in the mounts n storage(may help) 2 before even setting up Google on first start up slide down notification bar click on wifi then long click it to go into settings n choose an open signal then modify network n either switch to static n configure the IP info if its not already there or switch to static then back to dhcp n then immediately reboot n on the next start up it should be working, the problem is that the ipconfig.conf file (/data/misc/wifi/) is not configuring itself automatically as it should but a restart or fill piweroff helps fordome rreason
AOKP - Android Open Kang Project
•Alot of customization added to CM9
CM9 - CyanogenMod 9
•Taking Android to the next level of speed, durability, and use.
Hows that?
The aopk A8 with the 3g and mms fix Worked for me !! :) :thumbup: mms is fix!!!!!
Worked for me too, but without a camera I can't use it for more than a few hours at a time. I have a supah cute baby and you never know when it's going to be a Kodak moment.
Sent from the BACKside of Tapatalk 2
Reactions: itsrayray
Thank you guys so much!!!
I think I can use this as my daily from now but if there's any camera fix could u please let us know asap. I'm using the CM9 version.
Anyone that wants the extras for alpha9... be patient I'll have them up by Monday afternoon. Had to run this evening because I was really trying to get aosp going.
confirmed that current version's mms and 3g work! camera preview still doesnt work. having problems connecting to home wifi for some reason
Well you got it going alright haha
AOKP seems to be the most stable, along with it having higher benchmarks in graphics and general CPU performance
I gave AOKP a 748 mhz clock and it out performed CM9 with a 787 mhz clock!
using anTuTu for benchmarking.
AOKP(748 mhz): 1456
CM9(787 mhz): 1445
CONFIRMED: AOKP has broken MMS
Downloaded Alpha9, verified MD5 sum. Backed up everything, wiped everything twice, formatted everything twice. Went to flash, no go. Jerry's green recovery. Glad I backed up.
Restoring now, will flash BobZHome's recovery and repeat the above.
Status
BrüZZi
