[ROM] Android Open Kang Project- Jelly Bean Style
My Twitter app isn't updating on today's build. Kinda annoying. On par with the usual bugs that come and go with the nightlies.
Thanks for link, so since this is a totally different Dev it seems, I would need to backup and wipe to try this new ROM instead of Skank's AOKP?
You may be able to dirty flash it, but I usually go clean when changing developers.
Twitter is chirping away at work this morning. I'm guessing that my issue at home was the idle wifi Grey out. No biggie.
Anyone else having an issue with wifi disconnecting when the phone goes idle/sleep? I have it checked that wifi stays on during sleep, but when I unlock my phone it has to reconnect to my wifi.
edit: going to try a different kernal
Thanks, the Skank AOKP folder is back up on GooManager and I flashed 1-10-13 this morning. I'll stick with it.
Maybe I just never noticed it before, but under battery should the "GPS on" blue bar be full from left to right and the Maps application using up the most battery? I don't have GPS on and I even Forced Stopped the Maps app, but the Maps Use Details (says GPS) still increases by the second. I even tried shutting off all Location Access.
Using MR1 and Lean Kernal
I had a nasty wakelock with Google Maps. After un-installing and re-installing it went away. Are you using Titanium Backup? I only ask since I feel that the issue stems from restoring from there. I know that I have issues with Facebook re-installs from Titanium as well.
Yea I used TB. I just uninstalled and reinstalled and looks like Maps isn't on the battery screen anymore, thanks.
So I saw a video on Twitter showing off a work-in-progress feature that allows you to hide the navbar (and swipe up from the bottom to make it pop up). That seems like a neat little feature, hope we see it soon.
That would be nice on my next device.(Nexus 5) However my notification and nav bars have burned in on my GN. There are clearshadows when a video stretches out the screen.
I haven't had that problem, myself, but I've feared it enough to shy away from using certain apps, and whatnot, that might've kept the screen on long enough to do that.
Is your brightness turned up a lot?
Running JB Mr1 the 4.2 one. Sick stuff. Also flashed the latest lean kernel. 5.8. Sick battery life. Been listening to tunes all day at work and still have 30% battery. Loving this!!
Also if they read this. Instead of tiles i would love to see switches in the toggle menu. Like the quick access in the other menu but think switches look cooler.
That's a 4.2 feature by Google
Has anyone else noticed an issue in which the stock keyboard no longer automatically corrects typing just "i" to the capital "I"? It used to correct to "I" for me when I was using the DizzyThermal 4.2 nightly builds, then at some point, it stopped correcting to the capitalized version. I did a full wipe when I flashed to the official AOKP MR1 release, and it still doesn't autocorrect to "I". Kind of annoying, especially considering I do a lot of typing on my phone.
the native music app is not as appealing and easy to navigate than iPhone thats for sure.. but the speaker is pretty loud and clear....
video play back too, and still not happy with the apps in the market for it
i noticed this too.
I've noticed this issue on MR1 only. M1 worked fine.
LuisLikesAndroid
