[ROM][AOSP][4.0.3] Codename Android 1.5.5 [Full Open Source]
Never, ever ever ever ever EVER restore system data :)
Yes you should do a full wipe and reflash. Live and learn :)
Sent from my Galaxy Nexus
The last time I flashed a ROM I restored everything including system data and didn't have any problems. Must have gotten lucky that time. I went into recovery and did a wipe and rebooted and got back to the bare bones 1.4.0 and then did the backup of apps and app data only. I am back up and running without any problems. Just took a little longer to manually set everything up. All is well!
Thanks to all for your help.
Bryan
anyone still having an issue with Google wallet prepaid card? It still says unavailable for me.
It's a Google issue, not ROM.
Bryan
Yes you got lucky before. Bad habit tho.. Remember if you could just restore system data then devs wouldn't ask you to wipe it in the first place, lol :)
The Google Apps are no longer included in 1.4.0 and need to be flashed separately. It would be helpful to update the flashing instructions in the OP to let everyone know that. (It''s mentioned in the changelog, but not everyone reads through it.)
Sorry for the confusion about not adding the Google apps the op has been updated with the new version (thanks 2defmouze), I assumed everyone would read the changelog before flashing or updating anything.
Yes.. Another thing to note, due to legal issues the Gapps I posted won't be added to the official rom OP.. But we are all still free to use them. That way it keeps the devs' hands clean :)
Reactions: mclarryjr
Big problem here....maybe one of you can help!
1. Backed up apps and their data (NOT system data) with TiBu and then my screen settings with Nova.
2. Rebooted into CWR...did factory reset, wiped cache, wiped dalvik.
3. Flashed ROM
4. Flashed Gapps
5. Rebooted, started fine, restored apps with TiBu, worked fine.
6. Rebooted in CWR, flashed Nova
7. Rebooted, started fine, set Nova as default
8. Restored my screen settings, and Nova "suddenly stopped working"...now I'm stuck.
Any thoughts?
EDIT: Problem solved.
3. Flashed ROM
4. Flashed Gapps
Any thoughts?
You can't leave us like that...what solved the problem?
Reactions: gshock413
My problem?
Device is slower and from manager says stopped working when trying to boot into recovery.
Thoughts? Nothing new installed since update.
Everything working great here after update. Loving it so far. My only app missing is the News app. using Currents just missing widget.
Sent From My CodeName G-Nex Via Tapatalk
I believe this should be the google news app: http://dl.dropbox.com/u/47300967/GenieWidget.apk
Think you need to push to /system/app with adb... or with rootexplorer move it to /system/app make sure permissions are rw/r/r
then reboot..
Reactions: BayRican
then reboot..
I just tried using file explorer. I moved to system. How do I make sure permissions are rw/r /r. Edit: had a brain fart permissions are right now,I rebooted still not working.
When I flashed nova it installed nova version 13, but I had previously updated it to version 14 when I made my backup. Version 13 didn't like trying to restore a version 14 backup. Updated the launcher to 14 and it restored fine!
Hmmm... Anyone? I'm noob when it comes to installing apps this way.. I know that works sometimes but not always..
If no one can help ill ask around and try to get that working for you later..
EDIT: did you try just installing normally like an apk?
Reactions: BayRican
After following your instructions i rebooted and didn't work still. I did a battery pull and when phone booted everything was prefect . Thanks so much for the help. Awesome my phone is perfect now. Thanks again
Oh.. Lol ok cool, your welcome :)
Really liking this new feature :)
That's much like the Bedtime Mode on BlackBerry. Actually one of the biggest features I've missed since moving from BlackBerry to Android. I may have to flash this ROM just for that feature. :)
Running 1.4 now with Franco's latest kernel (17.2) and battery life is awful. Is the kernel that comes baked into CNA available on its own so I can flash it over Franco to see if that's the culprit?
http://db.tt/9KQLVE5B
Just wipe dalvik and flash.
Also remember ROM's and kernels always need a couple days or power cycles to settle before battery life is reflected properly
Reactions: ManBearPig618
ruhidubey017
