[rom] AXI0M
IM having some issues as well. 3G seems to be very inconsistent, constant grey bars with no 3g symbol the last few days.
Also, I have been getting 4-5 freezes. Last night I was at target, and I would hit the power button to turn the screen on. It looked like it lit up, but the actual pixels never changed to the lock screen. A battery pull was necessary, 2x.
Anybody having luck trying to run 1420 in SetCPU? Every time I go up to that my screen starts freezing as I try to move through my home screens or pull down notifications. At 1350, it's smooth as silk. Of coarse the answer is to stay at a max of 1350. I was just wondering if anyone else had better luck? If so, are you running a kernel different from the stock 2.3 kernel?
Some phones just aren't very stable at 1420. I've been following the leankernel thread over on rootzwiki and it seems that many phones just won't run reliably at the 180 or 1420 slots. If 1420 doesn't work on your phone, just dial it back to 1350.
Sent using Tapatalk
Camera is working now after a reboot or two. I am hoping the battery life makes it worthwhile. I am not seeing a bunch of noticeable enhancements yet. I realize most of the early ROMs are mainly under the hood improvements and not visual.
Axi0m 2.4 by DroidTh3ory
[YT]http://www.youtube.com/watch?feature=player_embedded&v=t6K16230lVs[/YT]
Hey guys, just flashed the Axiom 2.4 by DroidTh3ory rom. I have flashed a lot of roms, and this is by far the best i have used. it is sooo smooth. There is not any stuttering when going to the home screen form the app drawer or when going from the far left or right screen to default. It doesn't have too much customization, so you still have the stock look. i recommend everybody go to the link below and give it a try.
|ROM| AXI0M 2.4 | APEX V5 KERNEL |1/06/2012| - RootzWiki
I dont have access to a computer. I have axiom downloaded to my phone. If i do a factory reset it will deleye axiom correct? Will i be ok without doing a factory reset? Ive only had the phone 2 days and have installed just a couple apps
If you want a solid, trouble free install, you have to follow the instructions, which include a factory rest. It will NOT delete your downloaded copy of the install file for Axiom, nor will it delete your pictures. A total wipe like that only occurs when you unlock the bootloader. Will factory rest will delete your phone settings, home screen settings and apps. Everything except the home screen settings will get re-downloaded after the flash when you sign back into your gmail account. Sometimes a few of your free apps don;t automatically re-download.
One of the things I find particularly interesting (and somewhat troublesome) is that my phone doesn't charge when it's plugged in. The battery symbol flashes like it is charging, and it says charging on the lockscreen, but the battery percentage keeps going down. Help please?
Mine charged fine last night. I would try a battery pull, re-insert it and see if it starts taking a charge.
I love the fact we have the NFL mobile working on the release just in time for the weekend. 2.4 is running great for me just like the other builds :)
2.4 is doing great for me as well. I am going to load a Franco kernel on tonight and see how it does. Supposed to be getting great reviews.
sas9111
