[ROM][BETA] Quattrimus ICS
USB Mass Storage has stopped working. SD card is fine...the computer reads it when I plug it in manually through and SD Reader. But using the USB cord through the phone does not work. Any suggestions? Running CM9 V670 NIghtly Build July 31.
EDIT: Phone still charges through USB and the phone does know that USB is connected. Gives the option to turn on USB Mass Storage, displays that USB Storage Mode is in fact on...but nothing comes up on the PC and it says that a disk needs to be inserted. So it just sticks at being on without actually doing anything.
I can confirm that UMS is still functional.
Maybe there's something wrong with you computer?
Try a different port?
sent from my Zom-"Bean'(CM10 JellyBean).
i need help, first i dont know which to download? but i downloaded CM9 Build for device VM670 Beta2 mirror 2 because mirror 1 wasnt working and when i treid to install it it kept saying error and installation aborted any help please?
What recovery?
I deleted the VoiceSearch.apk from the gapps zip (so I could get voice search to work) but I lost the dictation button on the default android keyboard. Is there a fix to add this button back?
I downloaded another keyboard from the market....go keyboard is good
I'm running CM9 beta2 and it is running great. I have not seen a reboot on this rom at all. GREAT WORK TDM! I've been running cm9 since alpha and the progress of your rom is just insane. Keep up the awesome work.
Reactions: tdm
Problems with the gapps download site? Downloaded the gapps zip and it was curropted, now the page doesn't exist.
Im still having problems with ICS freezing and rebooting. Ive tried both cm9 and aoskp and both tdms and Bobs. Am I doing something wring or is it the roms?
did you overclock any? They all will most likely continue to do that until you do
Get me a copy of last_kmsg after a reboot and I'll take a look.
I can't do anything without a log.
Screwgoogle
