[ROM][BETA] Quattrimus ICS
I get the 'upgrading apps' thing every boot, but it only has one app that it upgrades every boot. And I have like 20 apps besides gapps.
It's not sd-ext. Internal has 20mb left, and sd-ext has 600mb left, which should be Moore than enough. It's another problem.. Perhaps with /data I'm guessing. We might need to bind more mounts from sd-ext to /data.
Make sure all your apps are moved from the sd card to the phone, not the ones already on the ext, just the ones on the root of the card. Then go into recovery, wipe dalvik, and reboot. That will move the rest to the sd ext
Ram is always 200 below, ICS is a resource hog too?
Hardware Acceleration adds RAM, amongst other changed. I suggest using KSM - even compcache if its still there and you're desperate for RAM.
That's the odd thing. I clean wiped for beta 1, and I already had sd-ext ready when I installed it, so there's no left over apps on the system for beta 1. Then I dirty flasheda nightly, then beta 2 over the nightly 7-23. So, considering that, there should be no apps that are not on sd-ext, except for system apps of course.
TDM thanks for such an awesome rom. One question though is anyone else having problems with geotagged photos. They keep showing that they were taken in Uttar Pradesh instead of, in my case, Florida. Still my favorite rom; keep up the great work.
Reactions: tdm
Must be the data then
Use goo manager from the market. tdm has the betas and nightlies there. He's still working out the kinks in ROM Keeper.
Sent from my Zombie ICS-VM670 using Xparent Red Tapatalk 2
I got it, but I don't know where to look to get his recent ROMs.
Used AOKP for almost 2 days, I noticed I get Reboots when trying to send a SMS when I'm plugged up via charging.
Without charging, it doesn't reboot.
Browse all files - devs - tdm - roms - quattrimus - VM670 for Betas or Nightlies - VM670 for nightlies
TGL which version you using cause I've been on the 7/31 aokp and besides messing with the oc aside that its been my dd can't stay away I'll go to gsnap and gtr for a lil but ultimately come back to AOKP
need help, i cant install it. everytime i try it says error then installation aborted. can anyone help? :(
i need help, first i dont know which to download? but i downloaded CM9 Build for device VM670 Beta2 mirror 2 because mirror 1 wasnt working and when i treid to install it it kept saying error and installation aborted any help please?
If you're not sure what you are doing, then you probably shouldn't be doing it.
Check to see if the Md5 checksum is correct.
It sounds like you have a bad download.
Are you wiping system, data, sd-ext, and both cache's before your install?
Which recovery are you using?
sent from my Zom-"Bean'(CM10 JellyBean).
Reactions: inceyet
try turning md5 signiture verification off before flashing the zip... (in recovery)...
Its signed, and works fine if its not corrupted. If it doesn't install, then they got a bad download, and needs to redownload.
khatunkhatunc
