[ROM][BETA] Quattrimus ICS
So do I, and I rarely have problems. However, it still could have been a bad download. Did you check the md5?
What would you do for a Klondike bar?
So are there corrupt links?? I still have beta 2.....it's been in beta 2 forever.
Sent from my Optimus S running VM670ZV5 on MetroPCS.
Same thing happened to me, I did download from my phone but everything I download comes from my phone, my roms, gapps and tweaks were all downloaded on my phone from media fire so I just doubt that's it but I'll give it a go
Edit: Samething happened, it aborts and says error 0. I even tried both version (orginal and V2) Im stuck here as how some could use it but i did flash some tweaks on this rom, Could that be it? like not enough room left on the rom? @Droiddekka has same problems
I just tried flashing it and got a status 0 error as well. So it looks like it may just be an issue with MDPI phones?
Lol don't get all teary eyed, quattrimus is about Android 4, and jb is still 4. ;) It is certainly going to take some work to get back to what we have with beta2, but we went through this before... Remember the 4.0.4 upgrade for alpha8? That sucked but it all worked out.
Last time on "As Quattrimus Turns":
As I.C. Sandwich (ICS) lays on his deathbed, J.B. (JellyBean) arrives at the hospital just in time to listen to his father's final words: "J.B., I've been in this world for a very long time. I've done things in my life that may seem impossible, but I couldn't give up. I had to endure it all to see it through. To ensure that you had a future to look forward to."
"I've also made a lot of memories with friends and loved ones, good and bad. But thanks to the support of the people that I cherish, you included, I can leave this world with no regrets. This is your time now. Don't let it be a waste. Goodbye son. I love you."
Does J.B. has what it takes to carry on his father's legacy? Or will it be nothing but a burden to him? Only time will tell "As Quattrimus Turns".
^Jelly Bean looks like a kid with greasy Hair.
Yeah. I noticed it to. HDPI files. I'm gonna do some messing around though. Good luck to you guys too.
I was looking around, and it seems that the Galaxy S (the original) only had 512mB of memory. I wonder how big the actual OS is for that build...
I haven't looked at the official requirements for ram but I have no reason to believe that 512mb is going to be a problem. It's the flash size that's our biggest issue.
I will be starting to work on jb shortly, and when I release, I expect it will require sdext. I plan to put system apps on it this time, which means you won't be able to remove or change your sdcard without either a backup and restore or a reinstall.
aginaoghenechojakewho
