[ROM][BETA] Quattrimus ICS
Barnicle wifi tether isn't working I haven't found a hotspot app that worked since alpha anyone got one that works
Works for me. Did u skip wpa supplicant
Reactions: fpoama
AOKP maps seems to be working MUCH better now.
i did just encounter a reboot while using voice search to navigate to an address tho.
That's does nothing if I skip wpa
Love the rom, i was wondering though if there is an issue with hash's kernel for kindle fire because it can't see barnacle wifi.
Reactions: tdm
Does anyone know how to set a normal size wallpaper for the lockscreen
Because hotspot "barnacle" for cm9 it only turns on but there's no connection!
Sent from my VM670 using Tapatalk 2
Kindle fire can't see ad hoc connections which are what all the wifi tether apps use. Google "how to tether kindle fire to ad hoc wifi"
Tried aokp beta, still can't get apps to load from the market. They stay stuck in the pre download state. I don't have a sd partition. Is it a must to get the downloading working?
Probably a dumb question but my SD ext has nothing in it even after installing apps. I partitioned the SD card for 500 mb right after flashing rom. Did I do that right or is there more I need to do
Pretty much, yes.
You'll be glad you did :)
Put your apk's in /sd-ext/app and delete everything in /data/app
Will try. Do I do this before I flash the ROM or after? Do I need to format sd-ext before flashing? Can I just cut and paste them all from the data folder to the app folder?
Thanks for all your hard work.
After
Yes
Yes
Reactions: dbacon84
I accidentally enabled automatic brightness, and there's no way I can disable it now! Display settings brightness has no automatic brightness toggle, and the display brightness power widget won't turn automatic brightness off. What do I do? :(
P.S. Can't find the disabling of camera shutter sounds in the sounds settings either...
P.P.S. Instagram crashes everytime I try to take a photo. :(
Edit: I'm using CM9 beta1.
Ignore it. Doesn't do a thing :L
Well, now my status bar brightness controll refuses to enable itself... Also, last time I accidentally enabled it, my phone was doing the auto brightness thing, which I don't want.
I should look into disabling that. I don't believe there is an ambient light sensor on the phone.
Reactions: BuggerZ
noroldie
