[ROM][BETA] Quattrimus ICS
a clean and thorough wipe/format is always recommended to weed out any errors/bugs that may/can be caused by a dirty flash... its pointless to report any bugs you find if you dont properly wipe/format/install fresh, as bugs could be from use of improper procedure and not necessarily the rom itself (following proper procedure)...
Actually, even tdm says a dirty flash does no harm when switching between quattrimus cm9 and quattrimus aokp. Its because they are still the same ROM, just different mods. Now if you're switching from 2 different ROMs ie, quattrimus and bobz ICS, THEN you do a full wipe.
sent from my un-dead sammich.
I had to chime back in and say i was wrong about the bluetooth voice dialing working. It works without bluetooth, but not with.
Sent from my LG-VM670
Thought I'd post this showing my phone running at 0%. Ran like that for over an hour today before it finally died. I did it after flashing the newest aokp nightly.
Bug? Or just a glitch?
Sent from my twice fried OV using Quattrimus as a pacemaker
Nice set up!
Mind sharing it in my Rom comparison/set up thread?
Did you wipe cache and dalvik cache?
Try wiping battery stats from recovery.
Or, maybe its the circle battery mod.
These are just a few suggestions.
M9-NIGHTLY-120605 Change Log: Disable ip6tables bandwidth control for the moment,some wifi tether fixes related to hostapd(not stable yet), disable dalvik heaps logs
The quoted text is what 1 device did to kind of fix wifi tether in their cm9 rom.
And they're using a froyo based kernel, so they're worse off than us.
I promised myself i wouldn't flash this again until the new kernel was working. Tdm, like Rob Schneider would say on an Adam Sandler movie, "YOU CAN DOOOO IT"!!!
what's the best workaround for recording/viewing video cam files?
I'm on aokp 724 currently.
uniconstru01
