[ROM] CM7.2 Port for Optimus S by thekraven 3/9 zvd only
It looks like the link to the most recent build isn't working again. Can anyone else confirm thekraven's dir on goo.im is missing again?
It is yeah, my files were gone again when I looked last night (this was after re-uploading some of them on sunday night/monday morning); hopefully we just jumped the gun on re-uploading stuff.
In the OP, it says mic doesn't work with headphones in. I'm really confused now, did it ever get fixed?
Sent from my LG-LS670 using Android Central Forums
If you don't use headphones or a headset, then phone mic works like it should. That patch just makes use of the phone mic when using headphones.
Maybe I'm the only one here, but I find that the headset patch works, but is a little tempramental (sp?). Not a deal-breaker though, this ROM is awesome!
Any reason why data isn't working even with a clean install? Data works on stock but not this. 3/9 build
Voice/SMS works fine.
ZVD Baseband.
Just switched to the Ice Cold CM9 rom.
Could it be that I only get 1X data that's the problem and no 3G?
HELP! I need the correct gapps for my ZVD Optimus S and Kravens posts are all blank on 2 different browsers. Why are his posts different from the replies?
Removed link. I don't know why some of the first posts (OP's) were missing on some of the threads, but, yeah, they're back.
byronsss
