[ROM] CM7.2 Port for Optimus S by thekraven 3/9 zvd only
I have been on thekravens cm7 for a while with zvd to zvj patch no issues to report for me
Sent from my LS670
Thanks, It was suggested that I run this rom if I only want to use my phone as a Media device, not a phone. Do you think that was a good assessment?
Yes it is. One feature I like about this rom is that you can turn on airplane mode to disable all radio functions, and wifi is still accessable. That is a huge battery saver if you are using your phone as a media/wifi only device.
Should I revert back to stock completely? To remind you what I am running, I have ZVH, DannoRom and Hydro Kernel.
No need to revert for a WiFi only device. Simply full wipe (I would use the debug format all zip I have linked to in Dante ROM thread) flash ROM then gapps.
Sent from my Nexus S 4G using Tapatalk 2
I had a stock ZVJ device. I used this thread to downgrade and this thread to root. I am now running DanteRom with HydroKernel. Any help or how to on how to get back to ZVD and install this would be great. Should I go back to the beginning with a fresh device? Does this include a kernel built into so all I have to do is downgrade to ZVD? I have rooted and done custom roms on other Android, as well as Windows Mobile and Windows Phone, devices but this one seems a little more difficult.
No need. Simply flash the rom, then flash the apropriate patch found here: http://forums.androidcentral.com/lg...zvj-zvd-zvd-zvj-flashable-zips-optimus-s.html
No baseband magic required.
Re: [ROM][WIP] CM7 Port for Optimus S by thekraven 9-2-2011
does anyone else get accelerometer issues? or is my phone messed up?
Re: [ROM] CM7.2 Port for Optimus S by thekraven 12-22-2011 zvd on
Small kernel update. WIP to get the files needed to work with cm7.
  • Based on ZVJ and Iscream sources. 2.6.35.7, thanks drew
  • Fast charge kernel, thanks jawz101 for the patch.
  • Fixed blackscreen wakeup issues when using Gingerkernel and Hydrokernels with CM7. Found the fix in the preparation of a possible cyanmobile release.
  • V2
  • Should be compatible with zvj roms and CM7 roms..
  • Only issue is video cam with this kernel
Steps to get the new kernel to work with cm7 roms only.
  1. New kernel View attachment hk-gb-CAI-v2--kernel.zip
  2. Libraries needed for the zvj kernel to fix whitescreen camera Gingerkernelfix3.zip
  3. If the home and menu buttons are switched flash this with my CM7. http://forums.androidcentral.com/at...-thekraven-10-10-2011-keypadfixfor.xredux.zip
  4. To use the fastcharge kernel function via USB, grab the Enzomatrx app here http://forums.androidcentral.com/op...harging-now-jawz101-kernel-4.html#post2257090
To undo, just wipe cache and dirty flash the rom+gapps again.
Awesome to see you still giving love to this rom. Honestly, I think your barebones version was my ultimate favorite rom on this device, and stayed longer on it than any other (heck throw the roms I have run on my ns4g in there and I think this is still true). Glad to see it get more attention.
Are there speed improvements on this new kernel? And maybe this wasn't intended to work, but is the fact that apks from the sd card wont install fixed?
Sent from my LS670 using Android Central Forums
apk's from the sdcard always worked for me. Did you turn that option on in settings/applications/unknown sources?
Yes, its on, but in the installation, the phone just freezes up... its weird... sometimes it works, but most often it does not. It works when I've just downloaded something, but not when its been sitting on my sd card.
Grr, I'm having trouble. I'm installing the latest IHO build, but then can never log into the Market. The Gapps installers don't seem to flash correctly from inside recovery, so I can't sign in. I have only Market (old version, not Play) and Talk, and neither let me sign into my Google account. They just tell me my password is incorrect. How do I resolve this?
I'm using Cannibal's Open Touch. Does that make a difference? It installed Cold As Ice just fine.
I should clarify my earlier post: I said "The Gapps installers don't seem to flash correctly from inside recovery", but there are no errors for the flash process. COT seems to flash Gapps just fine. But once I start up the new ROM there's no Gmail and the Market won't let me log in.
are you getting 3G or wifi? There won't be any gmail as you download from the the market. There's also the chance that the old market may not be working anymore. Try the other gapps and try to sign in.
OkamiSeishin
