[ROM] CM7.2 Port for Optimus S by thekraven 3/9 zvd only
hola tengo un proble ice todo lo q decia en la instalacion del rom pero nece q pasa si descarge archivos diferentes o que pero cuano enciendo mi cel no pasa de imagen de inico el logo y LG no pasa de hay ayuda
Descargar Rom. Descargar GAPPS. Coloque la tarjeta SD. Apague el tel?fono, mantenga pulsada Home /Menu (Uno de ellos, no s? cu?l). Limpie Everything After dar marcha atr?s. Flash ROM y GAPPS, tel?fono de
Perhaps someone could help me with this problem. It feels a bit nubbish, but here's a go:
My sprint LS670 appears to not like CM7. Any time I flash a rom that's based on CM7, I start to load the Rom and freeze at the boot animation. I'm not presented with a log or error, but it freezes (the animation stops, and I've waited 30 min for any movement. Nada)
I get a little sad to think of it, because I LOVE me some CM9 and 10 (thanks, BobZ!), but I've never gotten a CM7 rom to load on my phone. I was wondering if a)anyone else has had this problem and b) if anyone has found some kind of work around or way to pull an error from the phone that might explain the freeze. Thanks!
Make sure you are clearing system and data and everything else before flashing, especially if you are coming from a sprint ROM.
Sent from my EVO using Android Central Forums
Running CM7.2 on ZVJ with a patch, how do I hide or reveal my location? Can't find in settings.
Earlier today I flashed and booted to CyanogenMod 7.2. Because I was previously on HydroROM, I had upgraded my baseband to ZVJ, so in order for CM7.2 to work, I had to apply the ZVD to ZVJ patch (thanks, nightstalkr!).
I'm still in the process of restoring my applications from Titanium Backup, including the process of deciding which of those apps I still really need, but so far most things seem to work fine, with one important exception: I can't change my location setting. Previously in Settings, I could go to "Location and Privacy", where the first option on the menu was "Location Privacy" (or something like that), and then under "Location Privacy" there were the two choices "E911 Only" or "Location On". The Location On setting communicates your location to the navigation service, which needs that information to furnish turn-by-turn directions in real time. In the other setting, E911 Only, the GPS receiver can tell you where you are right now, and calculate a list of directions that you can read, but it can't navigate in real time. My device is now working as if it is in the E911 Only setting, and I can't find any option that will allow me to toggle it to the other setting.
Is there another place I need to look? Maybe a dialing code?
Until several months ago I had CM7 and I'm pretty sure I was able to do this then.
(Note to moderators: I wasn't sure where would be the best place to ask this question so I put it in the CM7.2 thread. I gave it a descriptive title so you can easily split this post into a thread of its own if you judge that approach to be more appropriate.)
Re: Running CM7.2 on ZVJ with a patch, how do I hide or reveal my location? Can't find in settings.
try reverting to the 2-7 build. i recall having gps issues with the 3-9 build, but never had issues with 2-7.
If you mean the one on 2-9-2012, I did use that one. However, I didn't flash the boot image; could that have something to do with it? Having flashed the patch, can I still flash the boot image, or do I have to wipe/clear everything again and start over?
there is no 2-9-2012 build :p. just 2-7-2012, 3-7-2012, and 3-9-2012.
the boot image should only be necessary if you use the 2-7 build, and even so it shouldn't have anything to do with the gps.
if you're on 2-7-2012 and the gps isn't working for you, then i dunno. wipe everything and try again? or play around with the gps patches on the first page?
I did mean 2-7; I must be spending too much time at the computer.
As for wiping everything it's probably not worth the trouble. The network's usually not fast enough to use when driving, and if I'm walking I can read directions or look at the map.
I simply went back to HydroROM, thereby getting a hands-on, up close and personal demonstration of how incredibly useful Nandroid backups are! I could have gone through the GPS fixes to try to make this work in CM7, but that would have taken more time than I wanted to spend here.
ok so i cant install anything from my sd card with the 3-9 build, and the kernel reboots itself on me. halp
Which recovery? There was no apps to sd-ex built in. This one is pretty much zvd only. Idk if anyone tested it with the zvj patches.
I am currently setting it up using the ZVD to ZVD patch and it's worked fine.
only issue I'm having is themes are not sticking. I'm going to poke around a bit more before just going clean wipe again (slow work day thankfully).
but phone and data is fine. I had to manually push Sprint's Voicemail upgrade APK to system/app because it wouldn't update from within the voicemail app.
I've been using HydroROM for a long time now, but am bored with the skin of it. Figure an ICS theme will at least hold me over. It's not like ICS is getting flash Player support anytime soon (the only thing stopping me from using ICS primarily... and QualComm doesn't seem to be making any progress on giving folks what they need).
Kudos! Hopefully I'll fix my theme problem and make this my daily driver.
Update: Clean flash, started CM7, applied theme, rebooted. Theme gone. So this was a fresh install and themes are not sticking. odd.
Re: [ROM][WIP] CM7 Port for Optimus S by thekraven 9-2-2011
Everyone keeps referring to "The kravens?cm7" rom and when I search that name nothing comes back. Is this rom the rom they are referring to? I want to make sure before I install. Also I rooted and running Danno rom and zvj. Will the zvd downgrade work to install this?
Yes, this is TheKraven's CM7 build. If you're running ZVJ, you'll have to use the ZVJ to ZVD patch to receive signal. It may also cause other bugs, since it's not tested.
ok wow i just realized ive been running the 2-7 version all this time... time to try out the new (not anymore really...) update!
I have been on thekravens cm7 for a while with zvd to zvj patch no issues to report for me
Sent from my LS670
molitco2
