[ROM] CM7.2 Port for Optimus S by thekraven 3/9 zvd only
Re: [ROM][WIP] CM7 Port for Optimus S by thekraven 10-05-2011
Yea I flashed Xionia just to write a new prl... Then flashed back over to Bobz so im good... I love your ROM but have been going through Freezes (No Reboots) On my phone and my girls... We both are running your ROM with stock kernel... I'd love to go back if the freezes get fixed...
It could be that I missed a setting, but is anyone else having an issue with no sound recording with the camcorder on the latest build?
No problem with mine.Try going to cm setting and look for sounds check to see if anything is turned off check camera mute and volume settings
OK First off how did you go about flashing the rom and what kernal are you using.you can try the camera fix zip in the list in his rom section
That camera fix is for the older makes.
iho BobZhome's 3.1 kernel is included.
Make sure your phone is zvd baseband and rooted with xionia recovery installed. If you are, Just follow the install instructions in the first post. Back up your current setup in recovery. Then proceed with the required data wipes in recovery .
Just installed the newest release yesterday...running smartassv2 at 320 to 806.... my screen will sometimes react like I'm touching on the screen and starts to open random apps or if I'm in my mail program it'll just start opening things I didn't even touch....also on interactivex I've noticed an occassional lag and my scrolling speed will sometimes slow down so much that I have to press really hard on my screen for it to sense my finger and allow it to scroll. I've also tried it with the 16bpp on and off. Every other rom I've been on I've yet to experience these issues. I've only ran reborn in the past but for the past many months I've been on drew's latest 2.3.5 I believe and I have not had this issue at all. Just some things I've noticed.
You might have to raise your min CPU speed up some. I run 825/600 and sometimes 844/729!
Sent from my LG-LS670 using Tapatalk
Also try on ondeman I'am running that and set at 825/600 with no problems
it might be some of the memory tweaks. I'll get a fix to remove them. Wipe cache, then Flash in recovery below. Let me know if that helps
Btw, when will the latest clock patch be released? Finally found a transparent theme I like! :-D
i just downloaded...wiped cache... install zip... clicked on the memory tweak and i get "amend script is no longer supported... please switch to Edify scripting.... installation aborted"
What recovery aye you using?
I was gonna ask how to get the visual voicemail back but I searched this thread and found the solution. Good to have it back! Didn't like any of the 3rd party apps.
riaz491
