[ROM] CM7.2 Port for Optimus S by thekraven 3/9 zvd only
every now and then the screen functions that I use in the notification power widget stop working. No toggle just the current setting flashes on screen each time the button is tapped: time-out set to 30 sec. Seems to only affect the screen functions like Screen timeout, brightness and orientation toggle. Reboot usually fixes it..once or twice
I had to reboot a second time. I've noticed that it's done this back to the 9/27 release.
Now, I hesitate to blame the ROM, because for one reason or another, I've ended up doing both a dirty and clean install of just about each version. and I can't remember of the other installs that did it were dirty or not but this one is, so fore now i'm blaming me...unless anyone else has experienced similar goings-on and what not. ???
Sent from my LG-LS670 using Tapatalk
Re: [ROM][WIP] CM7 Port for Optimus S by thekraven 10-05-2011
In the SMS settings you can change the color scheme to dark. Just open msg'ing and hit menu
Thanks! Saw the solution in a previous post and changed it to black:)
Ok try this one for the clockworkmod recovery
EDIT.Dont use this one.
Ok... got it at first and hated it lol it froze four times, not apps but system. Killed my battery even on powersave. But its been about seven hours and I'm starting to love it! Now I gotta see if it resets my contacts and keyboard in restart. The only thing I hate now is how long it takes for apps to kick in on boot up. Also, I LOVE the boot animation! Its the best there is! Oh and I have latest nightly as over now, is there a transparent clock for 10/4 yet?
I'll upload a version without the memory tweaks. Anyone check md5 of their 10-5 Rom downloads?
The 10-4 center clock patch is for the 10-5 build. It becomes clear when you use a theme that uses transparency.
Mine shows this ef8f3db67e51ee692e18a1894a51cabb
Oh, I'm really sorry about that, i saw what it did. Yeah reload Gapps. I fixed that file now.
Ok, I got a biggy... after a day of working. Well, I restarted my phone. Now it takes more than fifteen minutes to load apps, then once it does, it freezes and either locks the picture on the screen or the screen doesn't Turn on. Any ideas to fix this? I really want this Rom working!
What is your setup like? Did you do all the formats prior to install? , format boot, data,cache, dalvik,and system.
Any overclocking?
Any apps2sd or similar?
How many apps?
Any overclocking?
How many apps?
setup was complete wipe and system and everything even tried dirty flash. No overclocking. But I had all my apps on my SD card, I moved them, and for now its working.
thanks for the link to the theme looks great
I did notice some FCs in the 10/5a version, so I reverted back to 9/29. I have the feeling though that the battery life in the 9/29 is shorter than what I was used to. Should I update to 10/6?
Just updated to the newer one. Very flashy boot screen, will let you know how it goes.
I didn't find any information about the kernel that comes with the rom. Does it support data2ext? Can I use ext4?
byronsss
