Thanks so much for this! I am brand new to this world of rooting (etc) and your directions were pretty easy to follow!
The only problem I am having right now is that I love the Swype keyboard, and I am guessing it isn't compatible? I reinstalled it with Titanium, but it keeps crashing, so I had to uninstall it.
Anyway to make it compatible? Anything like that?
I have an LG Optimus S and I have big fingers- the keyboard is pretty small for me.
Thanks!
Karen
Assuming you tried to restore the stock version, that will not work. You'll need the official beta from swype.com.
I have the 10-10 IHO, I don't think I have the Kernel though. (still learning as I go!) I don't mind putting it on and testing for you... More learning for me! Just tell me what to do.Anyone testing the 3.2 IHO Kernel? I'm working on a 10-16 build and the headset mic is not working with that kernel. It works fine with the 3.1 kernel. Just wanting to know if it is working for anyone else on the earlier builds.
New kernel from BobZhome to try. Currently testing.
* Interactive governor readded, I believe it is more responsive from idle than InteractiveX. So it may help with audio streamers, but sacrifice a little in battery life.
* Headset button fixes built in.
Kraven: Can you please explain what you mean when you say "Headset button fixes built in"?
Thanks!
Sent from my Android device
Question any way to fix the multitouch? seems in cm7 builds multitouch is a little wack lol
Thekraven: I reverted to ZVD on my main device so I could try your CM7 builds. Bravo, sir. Bravo.![]()
