[ROM] CM7.2 Port for Optimus S by thekraven 3/9 zvd only
Re: [ROM] CM7.2 Port for Optimus S by thekraven 12-22-2011 zvd on
this sucks. It's not for ZVH either :/ YET :/
Personally, after all I've heard about ZVH, I'll wait for ZVI (or whatever they're going to call the next update) before jumping from ZVD.
Future plans for CM7:
  • tackling the handset mic with headphones plugged in. Current condition is flashing a zip to have the handset mic working, but lose headset mic capabilities. Partly working that way.
  • ZVH radio work. Currently looking at radio logs and seeing what if...still we might be baseband limited.
Oh, that's really constructive to a guy who is working overtime to make a solid port of this great project for us. You can be critical of any release or mod, but don't be rude and ambiguous.
And just because you chose to accept an unstable update does not mean that every ROM needs to be instantly moved to that. CM7 has enough little bugs; some of us appreciate that he is using the stable radio release under the hood. Chances are that he and others have experimented with using ZVH under CM7 and there is good reason they have not put anything out for it.
Dude, the kraven is making cm7 available at his own will. Maybe you should donate just for being an @$$.
I guess you can't please everyone...I've never been more excited over a ROM than this one the entire time I've had my phone! Too cool!
The kraven has been more than generous with his builds. No one has a right to knock him over anything. This rom made my optimus run smoother and faster than any stock ROM could ever do.
Sent from my PG86100 using Tapatalk
Wow I love the new update! Now I don't have to look for themes that support transparent statusbar anymore. I can just change it in CM settings!
Quick question, is there a fix for this? (the * 0 # are covered)
Reactions: On3wheels
1. None of my apps are auto updating? Even with all checked to.
2. Can't call any Facebook contacts without editing the number and removing the +1? I thought this was fixed?
I'm having the same issue when using voice actions. The +1 prevents calls from going through.
I'll check, the +1 was fixed in the prior build.prop files. Actually didn't get much feedback on if it worked before.
Edit: the same additions are in the 12-22 build.prop. Maybe the new CM t9 dialer doesn't support it yet. I'll make the old Contacts.apk available too.
Here is the 12-12 old dialer (Contacts.apk) . Just flash in recovery or push the file inside to /system/app
Reactions: glenesis
I'm using ICS from market, this dialer issues was actually on the older builds as well, and I figure most people don't use the dialer very much while in-call. It is usable still, just though I'd bring it up. Again, this only happens when using the dial while in call to automated systems that require feedback e.g. walgreens, etc.
I'm actually still in the 12/12 build...
Only one person said the +1 dialing worked. It seems it still doesn't work in CM7.
For the other problems, have you flashed the 12.12 update permission fix? I updated the 12/12 ROM zips to have it corrected. Newer zips are 12.12h.
Going to report on 12-22 just downloaded
Kraven, is there any big changes between the current release and the 12/22b that was out for testing yesterday?
Jokerman
