[ROM] CM7.2 Port for Optimus S by thekraven 3/9 zvd only
Re: [ROM] CM7.2 Port for Optimus S by thekraven 12-12-2011
MDPI , I posted links quite a few pages back. If i can find it i'll link it in the first page. Try xda or the market for these themers Jasonevil , zdune , Achep , Sonny Sekhon
i'm thinking about posting just the mdpi version of my themes over here too....just for easy access for people that use our phone.
So, according to this post by the CyanogenMod team over on Google+, they've all but stopped working on CM7 to switch gears to CM9. My question is, is the current (2011-12-12) build up to date with the latest contributions to the CM7 code base or, will we be seeing one more update before it's done?
I think they froze developing for CM7, and I've seen them hold off on some features to save for CM9. But they will continue to push fixes and patches when they get approved thru Gerrit review.
There is a 12-18 test build floating around.
Reactions: CardcaptorRLH85
So it's ICS or F.U. from the CM dev team?? I understand that it's a new project and they want to move forward, but they are still just hammering out the bugs to get CM7 on a few more devices.
After testing the new 12-18 kraven rom, some cool tweaks, very fast, mms, data, phone calls, wifi seem to be working great!!! Also wanted to say camera, video recorder also are working and google maps worked great finding me in about 10 sec.
From what I've seen it's not quite that bad, they still have a few people doing general bug squashing on CM7 and the teams that are developing for specific devices are still working on those since the same issues may prevent CM9 from working on those devices. However, CM7 at this point is 'feature frozen'. In other words, no new things will be added to it at this point. Also, since so many of the devs are spending most of their time on CM9, any non-critical fixes may be a bit slow in coming out for CM7.
@thekraven thanks for that information, I was just trying to figure out what the future was for this ROM in the near term.
FYI- Some members of CM stated over a month ago that getting more devices included before ICS is released would be difficult to say the least (they actually weren't that polite ;) ). However, those of us working on IHO are still adding some features from time to time. Since CM7.2 is all but frozen, there's no reason to remain 100% pure CM, when we can kang the hell out of it and make it better for our phones ourselves. ;)
I have recently added an option to change the status bar background, with Theme, Custom Color, and Transparent options. Next, I plan on adding options for changing the notification drop down's background and menu item's colors, and an option for changing the overscroll glow effect as well as adding overscroll glow support outside the general UI.
https://github.com/JerryScript/android_frameworks_base/commit/c3b92aa4875e7998903c354c764c0fdd557658c2
https://github.com/JerryScript/android_packages_apps_CMParts/commit/e1ff61d0c5092aeea1c43e6f9a7616bc99e74001
While I realize these are mostly theming options I'm planning on adding, we will be adding/fixing/updating other features and issues as we can. ;)
Hi! I have been using builds of this ROM for months now, and I love it. Big and very special thanks to theKraven for all of the hard work that you have put into bringing the CM7 experience to us Optinus S users (IMHO, the very best free phone of all time, hands down). Lots of love, and happy holidays to all! Cheers!
Google+ won't install and gives me a package file invalid error. Was there a work around for market errors I'm missing other then clearing market data?
Google+ installed fine for me. I get those package file error from time to time only on Google apps, i uninstall the app and reinstall the newer version on the market.
There is a 12/12 update if you downloaded the 12.12g version. http://www.mediafire.com/?sthczpv8wx76fgk
There is a 12/12 update if you downloaded the 12.12g version. 12.12.update1.zip
I did this too, I uninstalled in hopes they'd go away but no luck... I forgot to make a backup so can't get the app on my phone.
I flashed the update when I ran into the problems and reflashed it this morning, it then looked like it'll install but craps out last minute. I'll just keep trying every once in a while...
I had the same problem with Star Traders RPG but eventually it worked so maybe I'll get some luck later.
Re: [ROM] CM7.2 Port for Optimus S by thekraven 12-12-2011 zvd on
Package file invalid can mean you don't have enough space, I realize it's a confusing message, thank google. ;)
"Not Enough Space" was the initial message. I recently stopped using data2sd with 12/12. I checked and had 30mb free. OK so I'll clear more, delete app data in Currents because it uses an insane amount. OK like 50 meg free. Download and Invalid Package File...
Strange, uninstall to try again and same error. Weird... Clear market data and uninstall updates. Same error. Flashed the 12/12 update and still persists.
Still no G+ on my phone :-( I can't find an apk online with the newest version and even then probably shouldn't trust a random apk... Plus I don't know if you're "allowed" to redistribute the app...
Probably just a freak incidence and either will work for me eventually or will when I flash the next update Kraven posts.
@thekraven, if you plan on pulling in the transparent status bar mod, you will need to add this commit to get the date showing again. It adds an animation to the notification icons that will prevent overlay when the date view appears.
https://github.com/JerryScript/android_frameworks_base/commit/c723fa98e4fed052cf52c43bda5ecabed50b8aeb
If you are interested, you can cherry-pick the overscroll color mod as well. ;)
Gerrit Code Review
(1 of 3 necessary patchsets, frameworks/base and CMParts required as well)
Reactions: thekraven
12-22-2011 build coming soon.
  • New CM T9 dialer and updated MDPI patches. May make some themes incompatible with the new dialer (Contacts.apk). I'll make the old one available.
  • Status bar color and transparency Mods build in. Thanks to JerryScript. Will need a reboot to see the changes
  • Mute volume change beeps
  • Volume buttons can be changed in orientation now. Just check 90 degrees.
  • Overscroll color mods in CM settings/interface
  • fixed Swipe to clear feature working better.
  • Latest sync with CM fixes
dialer works great, didn't break anything on my latest update of ice9
Re: [ROM] CM7.2 Port for Optimus S by thekraven 12-22-2011 zvd on
Is Bravia post processing engine included in 12-22?
no, but the file will flash over fine, just the build prop will say the older build.
this sucks. It's not for ZVH either :/ YET :/
mrtalha
