Re: [ROM] CM7.2 Port for Optimus S by thekraven 2/7/2012 zvd only
2/7 barebones is up in the oP.
I had this issue with another ROM and it turned out to be just a bad write from the PC. I deleted the folder and recopied, this time not rushing to disconnect the USB and it worked fine.
I'm not sure what coding they were though. You might also try clearing the data for your music player(s) so that it rebuilds. I hope that helps.
I tried this, but no joy. FTR what I did was to clear, but not delete, the Music folder on my Optimus and then recopy all my subfolders into it from the music folder on my computer. This sounds slightly different from what you did, but would that make a difference? I'm considering using the Double Twist synchronize tool, but I'm really trying to avoid doing that; it seems to dump half my music into the "Unknown Artist" category.
I'm trying this now.
ETA ~20 minutes later: This didn't work; the library simply no longer shows the WMA files.
ETA ~About an hour later still: Downloaded Winamp, and it doesn't play those files either. Curiously, though, I did briefly play one such file before it stopped working on them altogether. The WMA-extension files do not show up in the Winamp library either, which now tells me I have 37 albums. Thirty-seven!! That includes some podcasts, midi files, and other content which was directly downloaded onto the device. This means that, really, only maybe 20 of my 100+ albums on the PC are showing up. Really a bummer, and there doesn't seem to be a way around it other than reverting to stock and trying another ROM that will stay in zvd.
My battery has been draining pretty quickly and I did some testing and basically this is what I have observed:
With wifi OFF and bluetooth ON but not connected to anything and leaving the phone sitting completely idle for 8 hours:
With the totally stock LG ZVD ROM, the battery drops from 100% to 99%.
With CM7 (1.16.2012d-cm7.2-IHO-Kraven-signed.zip AND 2.7.CM7.offline.charge.booting.bootimg2.zip), the battery drops from 100% to 71%.
With CM7 with bluetooth off, it uses much less power.
I tried the XioniaRedux-08312011-signed.zip kernel and the results were the same for CM7.
In both of these cases I did not install any apps or change any default settings, just installed the bare ROMs. Is there anything else or any weird setting I can check that may be using up power? I don't understand why CM7 is using up so much power when bluetooth is on but isn't doing anything. I know that in general having BT on will use more power but this seems excessive... I was thinking there was some sort of setting for how frequently bluetooth scans for devices or something like that but I haven't been able to find any info from googling around...
try poweramp, i think it does software decoding of wma. Wma just isn't supported with stagefright. I read something about it would need to be open source with CM7 and not proprietary like wma.
I'll give it a shot.
To the community at large, and because I notice that a new version of the ROM has been released, how do we upgrade from one version of CM7 to the next? The baseband is now "unknown" and the OS version is now Gingerbread--i.e. no longer "ZVD only". Is the general procedure to first revert to stock, re-root, and install the newer version of the custom ROM?
How goes that script testing?
I'm still having problems with telephony (no service), but it appears to be linked to data2ext. Twice, I upgraded and restored apps, then installed d2e and lost service after the second boot after d2e. I have also upgraded and reinstalled apps and NOT lost telephony, even after 10-12 reboots (no data2ext).
I followed instructions on installing d2e, including formatting my ext partition.
I can live without data2ext, but I thought you might want to know about any issues.
My phone has data and wifi, but i cant make calls. it says every number is blocked, or when i text it says im disabled or something, i just flashed the newest rom.
any ideas?
OK, tried fixing permissions, still lost telephony. I'll try a completely fresh install this weekend.
