[ROM][CM9][ICS][4.0.4] Cyanogenmod 9, Android ICS 4.0.4
Yeah and Arjen said it might work for thrive to. With stuff like this its better to have more than just one person's feedback. I posted my results to let arjen know what happens on the thrive. And as far as I can tell I got just as far as you in the install process with identical results, so it may save him work with me testing same build on thrive.
Ahhh ok ;)
Sent from my LG-P500 using Tapatalk 2
I can say this, On the Thrive, the p505icskernal.zip gives me an abort error when attempting to install.
And I believe it's just a compilation error. It has the folder "p505icskernal" inside the zip, and I believe it should only contain it's contents
soundemonchan, It won't work, It's compiled wrong. Simple Mistake.
@Arjen, Idk if this is me being stupid or if it'll save time. I unzipped that file, and rezipped it with the folders in the correct place and tried installing it and it told me expects 4 args, got 3 then aborted.
Downloading. I'll report back in a sec.
EDIT: Kernel unzips fine, booting with normal colors, it's been going for less than a minute. I'll give it more time.
EDIT:Hangs on boot after 8 minutes. D: but then again I'm on the new baseband so someone else should try.
Hmm nevermind seems like everyone getting same problem. Arjen I thought we needed certain drivers in the kernel?
XD arjen is doing awesome. he probably doesn't have a phoenix or thrive or anything to test this on himself so we just gotta test and report bug by bug until he gets it bootable.
.....I know that....he's an lg optimus one developer......and further more, I've researched on this alot and was informed that we need certain drivers in our kernel. Just mentioning.
LuisLikesAndroid
