[ROM][CM9][4.0.4]Touchwiz UX [0.1.0 - (7/14/12)]
Re: [ROM][CM9][4.0.4]Touchwiz UX [0.1.0 - (6/29/12)]
Looks good. Although the LG UI didn't lag for me at all Trying arjens new touchscreen fix rom and if it doesnt fix what I think it does then I'll try this rom out.
I have asked _Arjen_ if I can base this rom off of his, rather than Hehappy's.
I don't like TouchWiz, but I do have to congratulate you ;) Getting that took you a while I assume :P
Unfortunately I'd love to use this rom but I have no cellular service with either download. I have a Phoenix
New baseband. I did the official gb update and rooted. So I think I'm on the new baseband. I downloaded both or thrive and Phoenix and had no cell service on either rom.
Currently running the latest cm9. But like I said I'm a fan of touchwiz and I'd love to use your rom
I didn't mean to say unfortunately. The from was very fluid when I flashed nd it looked great but just no servce
Do you know how to do a log cat? If so can you send me one?
The fix should be up in a jiffy :) Figured it out.
Reactions: AdictoDigital
I can and can't. I don't have access to a computer right now so I've been doing it all from my phone. I'd have to keep jumping back and forth roms and get a wifi hotspot to do anything
Thanx that was mighty kind of you! I could do more if I had my laptop but for now its my phone nd McDonald's :-D
Hello bownz!!! :)
Yesterday, I installed the ROM on my LG Thrive...
Nice GUI... Nice ROM... But I have a problem with a lot of Apps, they crash. ie.: Check Root, Quick Reboot, Ping & DNS, AndFTP, etc..
Thanx a lot!!!
Hello bownz!!! :)
Thanx a lot!!!
I'll look into it...
Hello bownz!!! :)
Thanx a lot!!!
Did you wipe everything? For me that's always been the main cause of things force closing.
Everything works flawless for me except when I go to make a call, the phone app force closes. Any suggestions?
No clue, I've only touched the phone App to change an Icon.. :S
All good man. Texting and mms and everything works for me and that's most important. Incoming calls are fine its just calling out, but like I said its all good. Thnx for your efforts *thumbsup*
I'll give it my all right now. However I'm trying to port The stable MIUIv4 on XDA to our phones right now. (Basically without Bootbug, and still smooth) TRYING :p
Nice to see some different roms are arising for Thrive and Phoenix.
Sent from my iPad using Tapatalk HD
Yeah... Before flashing this ROM I did a:
1) Wipe Data / Factory Reset
2) Wipe Cache Partition
3) Wipe Dalvik Cache
4) Wipe Battery Stats
ClockWorkMod Recovery 5.0.2.0
I also have battery draining issues... :-\
MO Shm0
