[ROM][CM9][4.0.4]Touchwiz UX [0.1.0 - (7/14/12)]
I just flashed this rom. Only with this ics rom I'm having problems with fc's with es file explorer and es task manager. I cannot use the root features of either app. Have not experienced this with any rom before, ics or otherwise. I do like the speed and the look of this rom however
Sent from my LG-P506 using Android Central Forums
Dear bownz, thank you very much for your hard work... ;)
Unfortunately, I have to return to Stock ROM because of some battery issues... The battery is over heating... :-\
I have a more stable version, based off of Arjen's rom. Only issue, Phone app doesn't show up. Working on it.
Hello i have lg thrive p506 at&t .
what i need to see if is old bb or normal,
i am downlading this rom but dont know what i need to upgrade firmeware... only need cwm and this rom to update... i have flashed recovery an i have a back up to restore... can any help me to start
Thrive is always oldbaseband. There's a baseband fix in arjens cm thread that you can search for. You can also download arjens optimized touch screen kernel in the same thread. Just wipe everything in cwm and flash this rom then flash the oldbaseband fix and reboot. If you get weird colors (color banding) then flash arjens kernel an you should be good to go
I'm Recompiling everything from source, hope for a new release soon?
EDIT:
Just flash my Thrive Version. I should really change the names. The p506 version is Old Baseband. And the p505 version is New Baseband.
can i use this ROM over Arjen's weekly? without wiping Data?
What about phone call and other FC? are they fixed yet?
I install the rom, clean all the lyrics before installation, but information found in the SD of the app I had installed. and self-install the app again, the truth found the following problems:
Forced closure in almost all operations to open an app.
black screen background, can not get to choose a new theme.
Rapid consumption of the battery.
remove him relive 3d rendering for improvements in color.
reported for new users, you just have to download to install the recovery P500 CWM old baseband. reboot into recovery mode and manually search the rom on the sd.
then you give it to install the rom. expect to complete and restart the phone.
should turn on properly.
waiting for a new version of the friend: bownz
:D
Re: [ROM][CM9][4.0.4]Touchwiz UX [0.1.0 - (6/29/12)]
When i use touch wiz ux my call service, data, and sms doesn't work
birdsong2000
