[ROM][CM9][ICS][4.0.4] Cyanogenmod 9, Android ICS 4.0.4
Hey arjen, what did you do to get the colors fixed in the kernel? I've been trying to figure it out FOREVER lol. In theory couldn't I compile any GB or ICS p500 kernel with the fixed screendriver and have it work on the phoenix?
You know, I never asked how old you guys are?
Sent from my GT-I9300 using Tapatalk 2
im 29 been modding hacking programming for over 17 years lol
by the way no go on adb shell dmesg gets to the cyanogen(mod) screen and nothing not recognised by the computer at all
this is on an lg phoenix p505 with new baseband and loading only the zip (update-cm-9.0.0-RC0-p505-UNOFFICIAL_2012_06_01.zip)
Reactions: Oathkeeper1212
yep tried with the kernel updates as well and a nogo so seems something is different between the p506 and the p505 the p505 locks its self down tighter than fort knox when we use the zip files and the kernels like it never gets a chance to load any of the drivers to activate anyhting usb included before it bugs out :(
guess im going to head to bed its 2:54am here and 5:00am comes early will check back tomorrow after lunch sorry i was no help would have loved to pull that log to help make this happen with less headaches and drawing boards lol
From the kernellogs I received I found out what was causing it.
Doing a full rebuild of the rom, hope it's solved so I can continue on the 2 Thrive versions.
Send from my phone...
owo Emmanuel
