[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
ics photo test
Send from my VM670 using Taptalk 2
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 5/6 ZVD basesband Alph
Been testing a10f for about an hour on my OV. Everything seems to work, as far as I can tell. Downloading from the play store over 3g can be flaky though.
edit: got a couple of reboots just messing around with the camera. might be my oc. 480/806 smartassv2?
806 is pushing it. I often get lockups/crashes when i'm OC'd above 800.
I Always Have 806 Mhz At InteractiveX
Sent from my LS670 using Android Central Forums
Some processors are able to go higher than others, even though they're all the same model. So one person's optimus s may be able to function wonderfully at 806, while another's suffers from lockups and crashes. But remember all of the optimus s processors are only rated stable at 600mhz, so we're lucky we're getting anything above that! :P
Flashed the Test Boot 2 and haven't had any WiFi issues (neither at my mother-in-law's house or at home). The clock lagged by about 15 minutes though.
On a different note, the FCs occurring on the Reloaded ICS when attempting to turn on USB mount is a known issue that the developer is working to resolve. Obviously Alpha testers need the ability to move files from pc to phone, so I'm staying away from this theme until that issue is resolved.
How did you get this to work? I thought the wifi tether issue was a known bug with CM9? I've tried the version you linked as well as the most recent version, which allows you to set up either as LG Optimus or Generic ICS device. Neither worked for me. My device hangs at "turning Wifi on" and I have to reboot.
Alpha 10f is a beast I was at first Havering problems with my animations so I turned them off but otherwise its awsome
I just turned it on. That version has always worked for me.
Sent from my LS670 using Tapatalk 2
Thank you for posting that, btw. I had been using wireless tether for root users and it had been working great, but I tried it yesterday and all of the sudden neither my laptop or my son's wii could find the connection, though they could before. I tried the one you posted and it worked right away :)
OK can you guys help when I go to download things from the app store it says error purchising item
Gonna need a little more then this. What kind of error? Can you download free things?
Reactions: ens04
dhickman
